Anyone on here fitted one and know how to do it? (S2 elise, though pretty sure it would be almost identical problem on S1 elise).
Greg in 'I told you so' shockerrobin wrote:It seems like a bit of a chinese puzzle - I am sure there is a way, but I cannot quite see what that way is ... I have the cylinder head removed, so plenty of clearance, but whether I attack from top or bottom I cannot the pipe in
I'll keep the rad for emergencies if you're not using it.Michael wrote:Hi robin...why does the filter need to be binned...?
Do you want the Rad back perchance? Coffee table potential mostly....
Cheers, Mike
OK, that would be nice - will be making a start at 20:00 and AndyG may well be popping over with his sticky throttle problem.GregR wrote:You needing a spare pair of paws tonight Robin? A yes might keep me out of the pub for a change...
