Hard top lining
ferg f
Hard top lining
Post by ferg f » Sun Sep 13, 2020 7:59 am
Looking for some info, the lining for my hard top has started to come away from the hardtop, any good ways of fixing it?
It is not bad (at the moment) so would like to fix sooner rather than later.
Re: Hard top lining
Post by campbell » Sun Sep 13, 2020 8:55 am
Double sided tape?
Re: Hard top lining
Post by robin » Sun Sep 13, 2020 12:13 pm
Possibly some 3M spray adhesive? Tape might be hard to get a good bond due to curved surface. If you want to try tape I suggest the thinnest VHB tape you can find. This is 1mm. There are skinnier types.
https://www.amazon.co.uk/dp/B01DVWCXWG/ ... xFb8R966RS
ferg f
Re: Hard top lining
Post by ferg f » Sun Sep 13, 2020 4:11 pm
Cheers fellas, I'll try the spray and see how it goes
Re: Hard top lining
Post by campbell » Sun Sep 13, 2020 6:51 pm
See if it will grip to Velcro hook side?
Put a run of that inside the hardtop.
thesurfbus
Re: Hard top lining
Post by thesurfbus » Wed Oct 14, 2020 8:01 am
The foam between the outer and inner layers of my hardtop liner had started to perish (turn to dust), so I had to pull the whole lot off and I replaced it with black Suedeliner from Harrison Trim Supplies.
Not the easiest of jobs as it has very little stretch and I got a few crinkles in the tighter corners, but overall it looks really good.
Lotus Elise 220 S
