S1 Exhaust movement
Kinger
S1 Exhaust movement
Post by Kinger » Fri Aug 20, 2021 3:22 pm
After the SIDC trackday I notice my Exhaust had moved towards the passenger side of the car. I took the exhaust, Cat and Flexi pipe off and cleaned everything up. Set it all back up with new silicone mounting rubbers and the exhaust outlets sitting centrally in the rear clam.
After Wednesday's track day I've noticed it's moved back left to the passenger side, almost touching the clam.
I'm wondering if it could be the engine mounts needing to be replaced, would appreciated your thoughts.
Re: S1 Exhaust movement
Post by Mike Scib » Fri Aug 20, 2021 3:49 pm
Kinger wrote:After the SIDC trackday I notice my Exhaust had moved towards the passenger side of the car. I took the exhaust, Cat and Flexi pipe off and cleaned everything up. Set it all back up with new silicone mounting rubbers and the exhaust outlets sitting centrally in the rear clam.
Wouldn’t think it would be the engine mounts if replacing the rubber hangers fixed it last time.
Rubbers getting to hot then cooling with the exhaust off centre?
Kinger
Post by Kinger » Fri Aug 20, 2021 3:51 pm
Don’t think it worked last time, it was only central until I gave it the works on track.
mik
Post by mik » Fri Aug 20, 2021 3:56 pm
Just book a reverse track session. :thumbsup
2014 Evora S Sports Racer for him
2020 Audi E-Tron 55 Launch Edit for her
Kinger
Post by Kinger » Fri Aug 20, 2021 4:17 pm
Post by Stephen » Fri Aug 20, 2021 7:40 pm
Is the tail pipe loose?
Kinger
Post by Kinger » Fri Aug 20, 2021 8:53 pm
No, the exhaust hangers have moved through the rubber mounts.
Kinger
Post by Kinger » Fri Aug 20, 2021 9:17 pm
Another question on the same subject, how flexible should the flexi joint be on the Exhaust link pipe. Mines seems pretty rigid ?
Post by Scotty C » Tue Aug 24, 2021 9:25 am
have you been feeding it viagra?
Kinger
Post by Kinger » Tue Aug 24, 2021 9:28 am
Post by robin » Sat Nov 13, 2021 8:28 am
Has the back box moved through the rubbers or is it just the tailpipes that move?
Kinger
Post by Kinger » Sat Nov 13, 2021 9:47 am
Hi Robin, enjoy Spa today 😀😀
I changed the hanger rubbers at the same time as the engine mounts and exhaust stayed in position during the Oulton/ Donington days 👍
