Washer jet is blocked
james
Post by james » Mon Nov 06, 2006 1:30 pm
Winter is nearly here so I'd better sort this before those salty sunny drives arrive where you cant see anything through the winscreen.
Since day 1 of ownership the passenger side washer jet worked fine but the drivers side was always blocked. I've tried sticking a needle in but that didnt work. What do other people do to fix this? Replacement washer jet perhaps?
PS I dont want the DIY washer hose with holes in it fixed to my wiper type solution as I think it will look hideous. Thanks :)
Post by Gareth » Mon Nov 06, 2006 1:42 pm
No option so all you need to know:
http://www.scottishelises.com/phpbb/vie ... washer+jet
ironside
Post by ironside » Mon Nov 06, 2006 1:54 pm
Or replace the water jets, they are £3 each. Part no: A082M6369F
Simon
Post by Rich H » Mon Nov 06, 2006 2:15 pm
Don't be soft, a bit of mouth to jet is required (Or compressed air if you have such luxury!) Blow hard into the top of the jet (Might want to do this out of sight or you'll be arrested!) hey presto cleared jet! Worked for mine, but they are still bollocks. The wiper mounted ones aren't conspicuous at all thou and work well....
james
Post by james » Mon Nov 06, 2006 2:28 pm
Cool, thanks will try a new jet if I cant unblock the old one, then if that fails, I'll be off to the Peugeot dealer.
Baggy
Post by Baggy » Mon Nov 06, 2006 2:51 pm
Compressed air will knacker any NRVs in line. S1 doesn't have but don't know about the S2.
Baggy
Silver S1 111s
The Deen
tuscan_thunder
Post by tuscan_thunder » Mon Nov 06, 2006 2:52 pm
I use either an airline off a compressor and blast that down it, or use a pressure washer, just touching the nozzle of the washer. Full pressure down the line seems to work well.
