Headlamp bracket
macca16
Headlamp bracket
Post by macca16 » Fri Sep 08, 2023 7:38 pm
When replacing a headlamp bracket
I’m assuming getting rid of all the old tiger seal and reapplying to the clam is the best approach?
Only advantage I see in not taking it all off is the pre-made guide for alignment of the bracket.
Thoughts?
macca16
Re: Headlamp bracket
Post by macca16 » Fri Sep 08, 2023 11:03 pm
Hacked off much of it but left enough to get a fit easily in the same position
macca16
Post by macca16 » Sat Sep 09, 2023 3:58 pm
macca16
Post by macca16 » Sun Sep 10, 2023 12:26 pm
Sorted
macca16
Post by macca16 » Sun Sep 10, 2023 6:35 pm
Spot the problem?!
Post by Stephen » Sun Sep 10, 2023 6:42 pm
Do you have a pick up tool?
macca16
Post by macca16 » Sun Sep 10, 2023 8:07 pm
No, but easily sorted thankfully.
Nice to get another simple job under the belt. I’m sure they’ll be plenty more tricky ones.
MLCELICES2!
Post by MLCELICES2! » Sun Sep 10, 2023 9:09 pm
Tidy job. Did you just do it with the wheel arch liner out?
macca16
Post by macca16 » Sun Sep 10, 2023 9:11 pm
Just bent it back and held in place with a stick against the brake disc. The fuse box screws have seen better days so I decided to leave that for another day.
MLCELICES2!
Post by MLCELICES2! » Sun Sep 10, 2023 9:14 pm
That’s good to know thanks! Mine are pretty bad so will need done at some point as well.
Post by Stephen » Sun Sep 10, 2023 10:35 pm
Just replace them with some stainless ones.
