I am swapping my ECU. My Emerald ECU has no Manifold Air Pressure hose inlet, so, the idiot question is :
1) How does it know the MAP?
2) Should I blank the hose with something?
Sorry if this is a bit lame for you tech guys
Best regards,
Mark
I assume you have an S1 PTP 170 and are fitting an Emerald in an attempt to make it idle better and run on very low throttle positions without kangaroo-ing?M Collins wrote: An educational couple of hours
Best regards,
Mark
Yes, it is an S1.robin wrote: I assume you have an S1 PTP 170 and are fitting an Emerald in an attempt to make it idle better and run on very low throttle positions without kangaroo-ing?
The overrun issue is probably because you don't have the fuel cutoff set in the map, or possibly you do, but with the wrong parameters. It should cut fuel on near-zero throttle above 2,500rpm or so.
To be fair, that engine was extensively 'loved' by me for 2 years running a good 180bhp before it started that nonsenseGregR wrote:Oil consumption has been experienced on here before, and led to a replacement engine - search for 'shugmobile conversion thread'. I think he was using 1l per trackday though
Had an S1 PTP165 but with their ECU, not the emerald. Now have an emerald on an S2, though not running yetM Collins wrote:
Yes, it is an S1.
I have changed the throttle pot setting that causes it to cut the fuel, it should now cut off the fuel if the engine is running over 2500 rpm and the throttle is lifted. It still feels very light though, and I am not used to the change down requiring so little "blip".
Robin, from your description, I assume you have either used one or own one, so did you find engine braking was very much lighter with the Emerald, or have I missed something somewhere?
DIY, it's the only way to know what's been done and what's been bodged; and then you also have no-one but yourself to blame afterwards eitherThe PTP head was fitted by sinclairs, I assume it was them who cut the old intake off, and so I assume it was also them who cut the replacement ducting 2 inches to short and failed to secure it to anything![]()
Engines fitted with PTP kit (and properly "loved") go through pistons and rings much quicker than standard cars. You've probably lost some compression and are burning a bit of oil (and this may fit in with the engine braking being light too, but only if it was always really like that).The last thing we noticed in this flurry of tender loving care, was that she was practically out of oil - last serviced 7K miles ago. Does anyone else find that they are drinking quite a bit of oil?
If you take out the advance settings at zero throttle above 3k and replace them with 5 degrees or so, then that may help provide more engine braking by killing the engine's power quicker.M Collins wrote:did you find engine braking was very much lighter with the Emerald, or have I missed something somewhere?
