Starting problems
vet111s
Starting problems
Post by vet111s » Wed Dec 13, 2006 2:38 pm
Bit of a lengthy history;
Was away for 4 days last week. On returning car was fairly sluggish starting and when did would not idle and kept cutting out. Ran for a short while, stopped the engine and then when restarted seemed fine.
Again didn't run her for 3 days at the beginning of this week. Tried to start her this morning-the fuel pump ran and the dash did it's normal thing however the starter wouldn't turn over. Sound just like a partially dead battery or something more serious? Havn't tried to jump start yet as cannot find my owners manual to get access to battery and wiring for wiring up for jump start. Is this worth a try 1st?
Post by Rich H » Wed Dec 13, 2006 3:16 pm
If the starter isn't turning then batt would be a good start. Quick to check, let s know if it works!
MacK
Post by MacK » Wed Dec 13, 2006 3:47 pm
Yea try jumpstart, mine gets tempremental like that when unused for a few days. I have a booster pack all charged and read in the house for when needed, e.g. tonight :roll:
vet111s
Post by vet111s » Wed Dec 13, 2006 4:08 pm
cheers guys. Don't think will try that today-bonnet might get blown away, that or act as a sail and the whole car will blow away! Here does one lay their hands on a battery pack like that? any preferred brands etc?
MacK
Post by MacK » Wed Dec 13, 2006 4:32 pm
http://www.mynewcheap.co.uk/products/ca ... start-kit/
As an option, though Halfords, Machine mart, Skrew-fix etc will all do them, and possibly B+Q etc too. I got my one in Costco.
I'd recommend getting one with a small air compressor in it too, for inflating your tyres.
Brigita
Post by Brigita » Thu May 24, 2007 8:59 am
Was hoping i'd find a post about this - i popped out last night to drop a dvd back to the shop and when i came back to the car it wouldn't re-start (tried 3 times). But after leaving it for 10 minutes and re-trying, it started fine..... strange!!!
Any ideas? Could it be the battery (like Vet111s)? :?:
B
:wink: :D
Elise S2 Racetech
Cobalt Blue ;-)
MacK
Post by MacK » Thu May 24, 2007 9:23 am
Was the engine cranking and not firing or not cranking at all?
Has it been sitting unused for a while?
It would be strange for it to be the battery if it had just started it and you drove for a short distance.
Brigita
Post by Brigita » Thu May 24, 2007 9:50 am
I use it every day Mac, it cranked up and fired but then died (each of the three times).....
Elise S2 Racetech
Cobalt Blue ;-)
Post by Shug » Thu May 24, 2007 10:27 am
Sounds more like the fuel pump isn't running right. Maybe ECU connected - worth popping over to MMC and getting them to stick the check tool on it.
Does it do it often? If this is the only time, it might just have been a wee electronic glitch (immobiliser or something) and it might never happen again. Feck knows with these overcomplicated 'Yotas ;)
Brigita
Post by Brigita » Thu May 24, 2007 10:36 am
LOL - it's the first - and hopefully last time!!!
I'll see if it happens again!
Cheers Guys!!!
B
:beer
Elise S2 Racetech
Cobalt Blue ;-)
MacK
Post by MacK » Thu May 24, 2007 1:13 pm
Rough Love required. :twisted:
:D
Post by Dominic » Thu May 24, 2007 1:41 pm
MacK wrote:Rough Love required. :twisted:
:D
:shock: :shock: :shock: :shock: :shock:
Sanjoy wrote:
OH DEAR.
Just google imaged Rought Love, DO NOT do this at work.
I now know that there is a Gay genre DVD entitled Rough Love and as broadminded that I am I did switch my VDU off till the room cleared.
No Se names listed on IMDB!
Brigita
Post by Brigita » Thu May 24, 2007 1:55 pm
LOL - i have to admit i wasn't sure how to take that comment..... :lol:
B
Elise S2 Racetech
Cobalt Blue ;-)
Brigita
Post by Brigita » Wed May 30, 2007 9:05 am
OK - so it happened again last night...... was getting my car washed just behind greens and when they'd finished it wouldn't start... left it for a couple of minutes and it fired up fine!!! WHATS going on??????
TIA
B
Elise S2 Racetech
Cobalt Blue ;-)
Post by robin » Wed May 30, 2007 9:19 am
So it cranks and catches but then dies? Does it catch properly or just fire a few times (i.e. do the revs ever exceed 800rpm)?
Did you hear the fuel pump prime when you turned on the ignition the first time?
If you did hear the fuel pump but the engine didn't really catch properly, my guess is that the cam position sensor is faulty.
If you didn't hear the fuel pump it's a wiring fault in the fuel pump circuit or the immobiliser is gubbed. Plenty of S1 immobilisers have failed already, so it wouldn't be a surprise if the early S2 variants didn't start to fail in the same way.
