What is this wire/plug for... ??
gorrie
Post by gorrie » Sat Jan 13, 2007 6:18 pm
And, should it be loose??
Just having a quick check over the car after collection and noticed a wire that routes under the Throttle Body and has a 1" (approx) black plug on the end. Only reason I noticed was becaus I was checking to see if the TB was stamped with a '52' to signify the Trophy/160 TB.
Any pointers on this wire greatly appreciated.... K-Series, 135 engine.
(how do I attach an image of it?)
Andy
[/img]
Stu160
Post by Stu160 » Sat Jan 13, 2007 6:49 pm
Hi Andy
There are a few spare connectors in the loom,how many pins does it have,as the pic is not working?
Stu
gorrie
Post by gorrie » Sat Jan 13, 2007 6:55 pm
Hi Stu... 2 wires, black/red.
Connector has black casing with a yellow block inside (with 2 pin holes). Car is going fine like, but just in case it's been knocked out by accident.
How do I post a pic?
Stu160
Post by Stu160 » Sat Jan 13, 2007 7:01 pm
gorrie wrote:Hi Stu... 2 wires, black/red.
I would think it is spare if the car is OK
Not sure about pisting a pic,there is a guide to it in FAQ .
Stu
gorrie
Post by gorrie » Sat Jan 13, 2007 7:02 pm
does this work??
EDIT: Obviously not.
I've stuck a picture on http://www.gorrie.freewebspace.com under 'toys & trackdays' if anyone cares to take a look. Would be greatly appreciated just to put me to rest.
DISCLAIMER: The rest of the site is poo... as it's just an area for me to play.
EDIT #2: Now uploaded pic to my avatar. Anyone???
Post by mac » Sat Jan 13, 2007 7:17 pm
Lamda sensor - might be a spare due to the fitting of the 135 head - where abouts are you?
I'm in Blantyre (outskirts of Glasgow - unless someone local can have a look your free to pop over sometime and I'll stick my head in the engine bay)
gorrie
Post by gorrie » Sat Jan 13, 2007 7:21 pm
I'm in Livingston.... Might need to get a hold of a workshop manual so I can see where the heck it's meant to plug in then (unless you can tell me)?
I have no signature.
Stewart
Post by Stewart » Sat Jan 13, 2007 7:24 pm
You need to find the image location, right click on the pic then hit the "Img" button then past the location then hit the "img" button again.
Should look like this "[ img]http://www.gorrie.freewebspace.com/images/p1000093.jpg[/img ]" without the inverted comams
Stewart
Post by Rich H » Sat Jan 13, 2007 8:02 pm
Flux capacitor. It was a factory option along with Michael J fox :lol:
Post by jj » Sat Jan 13, 2007 8:12 pm
I have a left-over connector in my car (yota engine though) but it is because I (like you) have an induction kit fitted. Maybe just something left-over from the factory setup when it is replaced?
Post by Rich H » Sat Jan 13, 2007 9:19 pm
More likely something off the car they nicked the engine loom form...
Post by robin » Sat Jan 13, 2007 9:27 pm
The 135 head doesn't result in any loom/connector changes for the S2 and there is no change in Lambda operation, though there is a different ECU for a 135R.
There are some spare connectors - you might find that one was once plugged onto the exhaust flap solenoid which is commonly disconnected along with the fitting of a sports exhaust.
In that general region there are four connectors that matter - the Throttle Position Sensor (it has three wires), the big bore connector for the injector harness (it has many more wires), the cam position sensor (it is one of the two wires coming out of the plastic Lotus cover - the engine wouldn't start without this one, or if it did, it would put on the orange MIL on the dash, and the plug-top ignition wires (it has 3 wires).
So I think your're safe ...
Post by alicrozier » Sat Jan 13, 2007 10:29 pm
robin wrote: There are some spare connectors - you might find that one was once plugged onto the exhaust flap solenoid which is commonly disconnected along with the fitting of a sports exhaust.
I think the exhaust flap is vacuum actuated. :?:
AJT
Post by AJT » Sat Jan 13, 2007 11:05 pm
gorrie wrote:Might need to get a hold of a workshop manual so I can see where the heck it's meant to plug in then
I have a copy of the service notes on a cd, will post to you if you want
Alan
gorrie
Post by gorrie » Sun Jan 14, 2007 1:33 am
You really are a responsive bunch... went out for beers and there's a flurry of answers upon return.
AJT... many thanks... I'll PM you my address in the morning... in case I get it wrong in my drunken state.
Andy...
