this doesn't look right...
craigieb
Post by craigieb » Sun Jan 21, 2007 1:27 pm
Hi all,
Just getting ready to give the car a quick wash and noticed this pipe isn't connected to anything at either end, here...
which looks like this:
and here...
...and my very very limited knowledge tells me that's not right :? :oops: . Should this not be connected to the airbox?
Will I be able to re-connect this myself without wheel-off / clam-off antics?
Any advice greatly appreciated :)
Craig
Post by GregR » Sun Jan 21, 2007 1:54 pm
from the pic of the side pod, it sure looks like it should be! Take a photo fo the airbox if you can, most of us are pretty unfamiliar with 'yota stuff at the mo so that should help :)
craigieb
Post by craigieb » Sun Jan 21, 2007 1:59 pm
ta. will do...just going to have another look/poke about.
craigieb
Post by craigieb » Sun Jan 21, 2007 3:06 pm
ok, bit the bullet and got the wheel and liner off and had a look. Looks like the plastic end of the pipe that fits into a socket on the airbox had somehow loosened off and come out. Onlt thing I'm unsure about is where the other end of the pipe should sit :? Couldn't see any other sensible place than as in pics below:
Before:
after:
Craig
Post by GregR » Sun Jan 21, 2007 3:26 pm
good work :thumbsup
So long as there's an unobstructed path from side-pod to tube, you should be fine :) Some on here may say that the tube itself unnecessary and the engine can draw air from the box fine as was. looks like you solved the prob though :)
Post by Rich H » Sun Jan 21, 2007 6:38 pm
that is correct the pipe just sits in the intake, pure Lotus engineering! The older cars had a snail shell shaped bit of cardboard (Well that what it looked like!) to fit onto the airbox
HTH
craigieb
Post by craigieb » Sun Jan 21, 2007 7:49 pm
thanks chaps :thumbsup
i think that's it back in place now and funnily enough i no longer get a loud roar over my left shoulder every time I put the foot down :shock: :oops: :lol:
Post by simon » Sun Jan 21, 2007 8:23 pm
craigieb wrote:i no longer get a loud roar over my left shoulder every time I put the foot down
Take it off again! :P
That's pretty much the sound a Hurricane or whatever makes.
craigieb
Post by craigieb » Sun Jan 21, 2007 9:30 pm
:lol: i did wonder...and have been looking at hurricaines as a result 8)
ninja
Post by ninja » Tue Jan 23, 2007 12:01 am
damn!!!
i actually knew the answer there too. having removed the offending pipe and box and replaced with a hurricane last year
ninja :drive
it's so seldom i can actually answer there questions :(
Post by robin » Tue Jan 23, 2007 8:16 am
Leave it connected - if there is any difference in performance either way it will be tiny.
