Cold heater air inlets
james
Post by james » Tue Feb 06, 2007 11:00 pm
So the S2 has a rubbish heater, when travelling along the motorway when its 0deg C the heater just cant keep up with the HUGE volumes of cold air being forced into the heater matrix.
So I thought "why not block one of the two inlets on the crash structure up for the winter?"
Anyone else done this? Duct tape at the ready.
Brrrrrrrrr :(
Mandy
Post by Mandy » Wed Feb 07, 2007 6:55 pm
Not actually done it yet but have thought about it.
Might try it for the car going back on the road in March.
If you do it sooner then let me know if it works.
Thanks
Mandy x
MacK
Post by MacK » Wed Feb 07, 2007 7:27 pm
That might work James, but I'd be wary of there not being enough air when you are going slowly or stationery. Not that I'm saying it would do any damage. I just mean anough air to give some reasonable heat.
Might work in conjunction with taping over the passenger side low level vent.
Michael
Post by Michael » Wed Feb 07, 2007 10:02 pm
is there really that much air coming through? feel the vents ...youll see there is v little. The matrix is simply too small and the fan too weak.
Therein lies your solution!
S2 Exige - sold
Boggo 911 (997)
james
Post by james » Wed Feb 07, 2007 10:53 pm
Michael wrote:is there really that much air coming through? feel the vents ...youll see there is v little. The matrix is simply too small and the fan too weak.
With fan @ position III all is ok when doing up to 40mph then u join motorway and the tootsies can immediately feel the cold air. I will try the duct tape at the weekend when I get back to sunny Scotland.
Dicey
Post by Dicey » Thu Feb 08, 2007 11:09 am
I read somewhere that there's holes in the tub/chassis that let air in at speed. You may wish to check for missing grommets/plugs and get busy with the Gaffer tape.
HTH
Mike.
Post by Rich H » Thu Feb 08, 2007 6:46 pm
bottom of the foot well on the vertical bit is a series of holes these are to keep your feet nice and cold as early cars had a tenancy to need the heater to be turned down and under the new EU rules Section 13 of the Idiot act: people cannot be relied upon to operate the controls of a vehicle as they might not be able to concentrate on their speedo and be tempted to look where they are going instead. To avoid this cars now must either have the heater on or off but to avoid having to turn the heater down should it get too hot, it will make little difference to the actual temperature in the car as that would be a distraction too. As a result drivers and passengers are required to dress accordingly and must at all times wear the approved underwear. Failure to do so can and will result in prosecution and summary execution as the jails are full.
HTH
/toasty warm early S1 faction :wink:
james
Post by james » Tue Feb 13, 2007 1:39 pm
For those interested, I did the modification at the weekend. Blocked the offside vent using very sticky Duct tape carefully applied.
Today was the first Mway drive and it actually seems to have worked. Engine water temp is unaffected :)
