S2 - Sports Tourer - Sports Exhaust - Which one is best?
Again, a question probably answered by "Do a search" or "pull up a chair", or "open a Stella, here we go".
I've bought a totally standard sports tourer (2001).
Which one gives a mixture between sound & performance?
(Apart from 2ubular as it has only 1 pipe)
David
David
I also have an 01 Sports Tourer.
I'm going to stick one of the new Janspeed Roadsport silencers on.
I'd love to get a 2bular, but i really don't like the single exit exhaust (unless you go for a 3 part diffuser, and panel eliminator kit - £££££)
I don't want it too loud in or out of the car, and from what i can gather the roadsport should be pretty good.
being a straight through silencer (before the pipe splits) it should be pretty good performance wise as well.
out of interest - anyone know where you can get one a bit cheaper?? - at the moment i'm just waiting for an eliseparts sale!
A.
A.
- Novice Racer
David,
You could just remove the vacuum hose from the actuator behind the driver's side tail pipe and see whether you like the improvement - this is a dry by noise valve so must make some difference!
None of the exhausts will make much if any performance difference without other changes to the system, so it really is just a noise thing.
I've got the Janspeed SuperSport 'zorst.... Does drone a little on M-way crusing as the revs rise (80-90mph). But for A-road blasts it's good.
EDIT: Please disregard the above comment as I have since found out after dropping the diffuser that I do not appear to have a Janspeed at all. Looks more like a Larini Clubsport.
I have no signature.
Yeah I'm in the same boat, but I'm def looking into a 2bular. I was the same, got put off by the single exit and was going to go for a Janspeed Roadsport or a Larini Club Sport. Done some reading on other forums for research and it seems Janspeed and Larini have had some issues, probably all sorted by now. Reading all through the exhausts threads I've never heard a bad word said against 2bular. I just kept looking at the website and the single exit has really grew on me, with the panel kit. It looks really cool
with the 3 part diffuser so not sure how it would look with mine, as its the old single type. If it does looks pants, I'll just go shopping for a 3 part diffuser. Unfortunately its going to have to wait a couple of months as I'm getting a new kitchen fitted, so £££ is a bit tight but will be trying to get one on by the summer. To be honest I cant really wait and keep thinking I'll rape the CC but we'll see what issues the cars got as I haven't driven it for 2 months and has been sitting outside in Aberdeen weather.
S2 Elise ST (V6 spec)
Audi A4 Tdi (Shed Spec)
Discovery 3 (Wifes Spec)
You won't get 12BHP out of an exhaust unless you've made a lot of other mods and still running standard manifold - changing the manifold and back box might then release the strangled horses ... but you would be running at 180-200BHP I think.
If it's power increase you want, the standard exhaust is good for at least 140BHP and more, no problem - you could swap cams or do some head work or both and get this sort of improvement whilst retaining a nice quiet car
IMO, the Larini sounds best on the K series cars and I had no issues whatsoever with mine. I believe the fitting issues were because Lotus changed the design of the mounts and didn't tell anyone!
Anyway, asking which is best isn't really going to get you anywhere because it's entirely down to personal preference. You won't get any noticeable extra performance so just get the one that sounds best to you
Pop along to Knockhill on the 10th March if you can and I'm sure you'll hear most of the options then.
Larini on the K does sound great.
Not really heard the 2bular on a K.
Here's my 135R with Larini and CRP
http://www.youtube.com/watch?v=8CvF2xa6rGw
Notice the reg number
It sounds much better now that it's mineGareth wrote: Here's my 135R with Larini and CRP
robin wrote:David,
Hi Robin
I had a quick look at the back box.
I cant see any vacuum pipes at the drivers side tail pipe.??
Where exactly is it ?
David
