Suggestions for correction have been header tank cap replacement, pipe to radiator leak, HGF and radiator leak from end-caps.
Well, the problem finally declared itself today, so congratualtions to Robin who told me on friday when I saw him that it would be the end caps that were the most likely problem. Stomped on the throttle and got a coolant spray from the drivers side onto the windscreen this pm. Limped home the few miles, access panel off and noted that the spongy stuff the radiator sits in is soaked with coolant. Dry however on the passenger's side. Also there are traces of coolant right around the plastic end-cap where the radiator crimps are
Will be ordering a new one from elise-parts but before that questions are
1) is it def the rad, or is there the chance of something else?
2) can I drive it to Jude Performance? Don't want MMC to have my car after previous experiences.
3) how much should I expect to pay for a front clam off?
Many thanks
NR
