Boot Lid
Titanium S1 111S (gla)
Boot Lid
Post by Titanium S1 111S (gla) » Thu Mar 29, 2007 12:01 am
Went to open my boot this evening and the opening leaver was jammed solid. No movement at all.
Was late so couldn’t persuade the girlfriend to come out of the warm to lean on the lid but not sure that will help with the leaver being absolutely solid.
Thoughts??
Graham
RDH
Post by RDH » Thu Mar 29, 2007 12:45 am
A massive spray of WD40 may do the trick
HTH
Rob / no idea how S1 boot lids function faction
Post by Rich H » Thu Mar 29, 2007 8:18 am
Pull down the wheel arch liner on the RHS rear and fish about for the cable and yank it from there. The handle is the bit that sticks a bit on mine as it's rusty.
when you get the boot open, undo the little cable clamp in the boot and pull out the whole cable from it's inner. I ran a load of WD40 down the cable outer to shift the water then gave the cable a good going over with a cloth & wire brush as required then lubed up the cable with white grease and pushed it back in. Has worked ok for the last 6 months.
Job's a carrot
