I am using Leda Recomended settings (Also using leda with road springs )
castor std
fr camber -1 deg neg
toe in 1.5 mm
rear
r camber -2 deg neg
toe in 3mm per wheel
rear height 8mm up from front
however i find the car can be twitchy over 80 tuts but has great turn in
i am going for stiffer dampers ( dynamics ) @ 400/550 eibach springs
and was looking at Gordons track settings on here
110/120 height ( I will use 115/123 )
front toe 0.02 deg out
camber 1.5 ( i will use -1 for road + stiff dampers)
rear toe 0.3 deg in
camber 3 deg neg ( i will use -2 for road + stiff dampers)
any negatives to the above settings as the toe settings are very differant than what i am using
I have the rack plates on order so will be fitting them
the tyres will be
195/50/15
225/45/16
marangoni zeta lina ( have good reports about these and won a free set from the internet site )
any comments
bob
GEO Settings
- tuscan_thunder
toe out at the front will make it turn in more sharply.
If you found it twitchy before, adding toe out at the front will only accentuate this feeling. I think you will need to add a wee bit more toe in at the rear.
The extra camber may make it tramline a wee bit more too.
seems a reasonably good set up to me though.
are you keeping the castor the same?
Mair throttle, less brake
