Replacing aS1 Manifold
CSK423
Post by CSK423 » Fri Dec 02, 2005 12:14 am
Anybody give me a step for a hint on this one ???
Bell and Colvill Super 140 S1 Elise
gordon
Post by gordon » Fri Dec 02, 2005 1:00 am
not done one, but ny manifold gasket's blowing a but when cold so i'll have to do it too.
Surely someone on here's done it, seems easy enough to get off as long as all the nuts come off no probs
CSK423
Post by CSK423 » Fri Dec 02, 2005 1:15 am
Taken from the seloc site mate, it's pointed me in the right direction
It will come out of the bottom with the downpipe still attached - you need to remvoe the oil filter and engien steady bar (one 19mm bolt into the subframe and one 19mm bolt into a braclket that bolts to the sump.
Also I hope you've alreay removed the crapp heat sheild, these disintegrate when you look at them and are 120 from Lotus! Repair waht you have with aluminium tape once you've removed it.
Then you can get it to come out, but you need to rock the engine forward an back.
You can make oit easier by removing the two bolts that holt the engien mount to the chassis, and once the steady bar is off you can pull whole engine backwards away from the bulkhead and that will give you more room to get to the manifold out.
Post by Stephen » Fri Dec 02, 2005 10:15 am
If you want to practice you can take mine off too. I have a gubbed lambda sensor & stripped threads in the hole, currently filled with a mixture of the old sensor and gum.
What I would advise is to wd40 the nuts every day for a few days before you start the job and use a 6 sided or surface drive socket as you really don't want to break a manifold stud or round a nut. The wd 40 will burn off but it will still leave trace residue.
gordon
Post by gordon » Fri Dec 02, 2005 11:40 am
I had a quick squint at it and once the heatsheilds and front pipe are off, it looks like it'll pull up the way no probs?? I'll report once i've got off my ass and done it, could be a looooooonnnnng while tho :lol:
CSK423
Post by CSK423 » Sat Dec 03, 2005 1:30 am
Stephen cheers for the advice
Gordon I want it back on the road ASAP I'll more than likely give you an update :D
gordon
Post by gordon » Fri Jan 13, 2006 12:38 am
Done mine today. No bother at all. Get the bonnet off to give better access (takes 2 min), take off frontpipe nuts, take off manifold nuts, take rear 19mm bolt out engine steadybar, disconnect lambda connector and get someone to lever the engine and pull the manifold out the top way. Fitted new gaskets and fetlled the manifold a bit and strengthened some of the welds while it was out. Took a ffew hours but some of that was working and rewelding the manifold. Car feels sharper off the throttle now and sounds much better. Back to popping and banging on the overrun again, cool:D
Post by mac » Fri Jan 13, 2006 11:18 am
Stephen,
Garage is still a bit on the wet side (hoping for a few dry days so I can arcopol the roof) but the facility is here any time you need it.
<even got a heater now :-)>
Post by Shug » Fri Jan 13, 2006 11:22 am
Heater, you poof!!!
< :thumbsup good lad :mrgreen: >
Post by Stephen » Fri Jan 13, 2006 10:52 pm
Cheers Mac that would be good. I'll chat to you about it on Thurs or give you a call. If you need a hand with the roof let me know.
