scott_e
by scott_e » Wed May 30, 2007 8:22 pm
need to change plate. went to garage with screwdriver but plate is stuck down
do i just haul off ?
what do i stick new one down with ?
thanks for any advice
scott
Kelvin
by Kelvin » Wed May 30, 2007 8:28 pm
I velcro mine on.
When it was stuck on with some super sticky wide tape the MOT garage used I simply used a metal wall paper stripper to force it off. Getting a Polish stripper to do it would be more fun though...
scott_e wrote:need to change plate. went to garage with screwdriver but plate is stuck down
scott
Baggy
by Baggy » Wed May 30, 2007 10:03 pm
I just stuck the new one on top of the old one....
I know it's added weight but I was in a hurry.
Baggy
Silver S1 111s
The Deen
- Site Admin
by simon » Wed May 30, 2007 11:11 pm
Just pull hard and it should come off. It will leave loads of sticky sh*t behind though. Just get some more sticky pads from halfrauds or get velcro from B&Q.
scott_e
by scott_e » Thu May 31, 2007 11:42 am
simon wrote:Just pull hard and it should come off. It will leave loads of sticky sh*t behind though. Just get some more sticky pads from halfrauds or get velcro from B&Q.
thanks guys. halford it is at lunchtime then.
by r055 » Thu May 31, 2007 12:09 pm
if worried about yanking it too hard you could maybe use some string and hold it either side of the glue, then use it in a sawing motion to cut through the glue bond between plate and mount.
Top tip to avoid damaging any paintwork!
simple yet effective
scott_e
by scott_e » Tue Jun 05, 2007 2:24 pm
got this done eventually .... however the only way i could remove all the glue under the old plate was to rub it with my thumbs ... so now i have a blister on each thumb ... which is cool as i was never sure whether to pop a blister or not ... so i popped one and left the other too see how it works out
