Can someone remind me of the recommended pressures for the Toyo T1-S tyres.
I seem to remember it was slightly above what the manufacturer recommended, to get rid of the side wall flex.
Thanks
Robbie
Toyo Tyre Pressures
- steve_weegie
I just put t1r's on my car and at standard pressure they were horrible. I dropped them to 24F / 25R but might try them lower as per richards suggestion.
BTW, the car feels completely different to drive with 195 tyres on the front - much less understeer on the exit of corners in my opinion. I wont be going back to 175 tyres, even on the std 5.5" rims but think it'll take a coupe more roundabouts to get used to them yet.
Toyos are horrible for 200-300 miles, they will get better, but pressures will not make them feel much better to begin with. They just get over it after a bit. Bear in mind they have 10mm of tread all over!
- steve_weegie
Not for longRICHARDHUMBLE wrote:Bear in mind they have 10mm of tread all over!
Are you running those pressures on an S2 or an S1 noops?NOOPS 160 wrote:Mines are 24 / 26 on T1Rs
Cheers all,
They're pretty olf now, although they don't get much wear as I'm in SFO now and they only get a run every 6 months (when I'm home). Couldn't bare to part with the car and keep it on here as the insurance was pretty cheap (<350 a year)
Just got back and they are a little soft so needed reminding where to set them
Robbie
Robbie
