S2 EXIGE WHEELS ON AN S2 ELISE
bobnitro
Post by bobnitro » Tue Aug 07, 2007 10:36 pm
Hi,
do S2 exige wheels fit a 111r ok?
ta
Bob.
Post by jj » Tue Aug 07, 2007 10:49 pm
Yup, straight on no problems.
bobnitro
Post by bobnitro » Tue Aug 07, 2007 10:51 pm
cool, thought so, but better to check...
thanks 8)
Post by Mr Momo » Tue Aug 07, 2007 11:12 pm
You selling the ones in the avatar ?
Emira - Volvo spec
bobnitro
Post by bobnitro » Fri Aug 10, 2007 9:46 am
No, lol
sorry Mr Momo, looking for a 2nd set for the track.
Bob
Edin430
Post by Edin430 » Fri Aug 10, 2007 5:34 pm
You'll need 20mm spacers for the back thats it :)
Well you would for mine not sure about 111r
Post by Mr Momo » Fri Aug 10, 2007 8:47 pm
No spacers required for 111R or SportsRacer ('yota hubs), but there are issues with suspension (someone will come along and link you to it !)
Emira - Volvo spec
Post by Shug » Sat Aug 11, 2007 10:23 am
Only issue if you're using sticky rubber (048s and the like) is that if you are driving it well enough to be using the rubber, then you'll overwhelm the standard springs and have it rolling too much. That leads to weird camber angles, too much weight transfer and less grip.
If you're going to be quick enough to use the sticky tyres properly then look at whacking on Exige (or other aftermarket) suspension too.
Of course, if it's just to whack on another set of tyres so you don't kill your good road rubber, then there's no issue at all.
bobnitro
Post by bobnitro » Sat Aug 11, 2007 10:35 am
Thanks shug,
correct me if I am wrong, but i think that my sports racer already has the exige suspension 8)
Bob
Post by mac » Sat Aug 11, 2007 10:45 am
I was going to say that I never had a problem running 48's on standard for a year - then I realised - I've now got massive big holes in the arch liners :D
Clarkie
Post by Clarkie » Sat Aug 11, 2007 10:59 am
What's the better suspension Nitron Sport Package with Eibach springs or the Exige kit? I read somewhere if you put 48's on you need to upgrade toe links? Is this just on earlier cars?
Clarkie
Post by mac » Sat Aug 11, 2007 11:03 am
You need to upgrade toe links on an S1 if moving to stickier tyres - not required in the S2 but you should increase your maintainance schedule with regards to checking them before and after any track or "involved" driving.
Post by Shug » Sat Aug 11, 2007 11:38 am
bobnitro wrote:Thanks shug,
Bob
Dunno (lost track of specs after Race Tech, TBH) - but if it does, you're sorted 8)
Post by Mr Momo » Sat Aug 11, 2007 5:23 pm
You may be right with the Exige suspension on the sportsracer - phone Lotus, they'll tell you....
Emira - Volvo spec
Post by Shug » Sat Aug 11, 2007 5:25 pm
Elise Sports Racer also benefits from uprated Eibach springs and stiffer Bilstein dampers
Googled - yes it's got the Exige kit - you're sorted :thumbsup
