Windscreen washer no working
- Scottynic
Okay guys, washers have stopped working is this common?
If its just a loose pipe can I fix it myself?
Or could it be the motor I hope not cos the car is only 7 weeks old.
Anyone had similar problem?
TOO FAST TO LIVE TOO YOUNG TO DIE!!!
- alicrozier
Later cars bottle is in the engine bay...jj wrote:Motor died on my S2; admittedly it was older than 7 weeks. Front compartment, passenger side, bottle lifts out for a look.
- russellphoto
Re: Windscreen washer no working
I have an S1 and the washer jets have stopped working. The pump is not working and the wipers don't do the usual wipe after the water sprays. Is this likely to be the pump or the stalk failing on the steering column?
Thanks
Russell
Thanks
Russell
2000 Elise in racing green. Soft top leaks but the hardtop is even worse!
If the wipers aren't following then it doesn't sound like the pump.
Fuse, or wiring maybe, although if the wipers work on their own (do they?) then this doesn't seem likely.
Is there a relay that controls the screen wash followed by wipe - might be that.
I suspect the stalk is the most likely cause if the wipers work in another position.
What he said - crappy Corsa stalk
