Knockhill Trackdays
Strictly for tarmac whores
Post by GregR » Tue Mar 28, 2006 1:05 pm
The_Rossatron wrote:How was the gravel experience Greg? Was it wet, what happened?
Put me down for two towing eyes if the group buy goes ahead! :)
twas fun - was busy chauffering Tom round stating how fun standard lizzies were. Got round clarks, headed for the chicane and tom said" is this on standard red Konis; I'm impressed!". At that point, turning in left, I lost grip at the back, thought I'd caught it, then it went sideways into the gravel. Gravel is my friend, there was a point when the wall seemed to be approaching quickly!
Post by Stephen » Tue Mar 28, 2006 1:16 pm
I,m up for one too, we could have done with some towing gear on my last road run, Eh Neil. I suppose you've gotten rid of that off roader now.
:wink:
Rich / Stu
Before we all wade in and get towing eyes have you had any more thaught re the rear towing eye / jacking beam I was on about a while ago.
http://www.freeyabb.com/phpbb/viewtopic ... isheliseso
Could someone have a think about the forces on the mounting points. Would you be better with 2 eyes and a strop between (bit of climbing rope and 2 Karibiners would be quick and effective) as both mounts then share the load irrespective of the direction or is a fixed A (as sold on line) better? The fixed A will result in both push and pull forces and may be more likely to result in a twisting force, especially if there is any sort of sideways pull.
If you go for the beam arrangement with 2 eyes then the U shape would be closed and probably add some strength.
My 2p
Post by GregR » Tue Mar 28, 2006 1:16 pm
mac wrote:They connect to either the left or right hand dome headed bolts on the undertray.
I'm going to speak to Lotus Motorsport before I commit to buying.
http://www.eliseparts.com/shop/index.ph ... cts_id=510
Are these the ones? If so, I guess Geary would be happy to knock something off the price for a group buy (or we could at least save oon postage!). Can you let us know what Lotus Motorsport think mac?
Greg
Post by Rich H » Tue Mar 28, 2006 1:51 pm
Stephen,
Job for someone with a metal workshop (Stu, can I borrrow yours?!?! :D )
With 2 eyes you will have to use a yoke to spread the load properly or you will only be loading one anyway. Only of use for a straight out pull. That A frame type looks good but expensive!
I can make proper (as in not climbing) rope tow lines if anyone wants. Spliced eyes in each end with or without steel eyes, shackles etc.
Anyone interested?
Post by Stephen » Tue Mar 28, 2006 2:47 pm
Rich,
If you you use a yoke / strop without a knot or centre point then surely the loads will be quite well shared. If you put a knot in the rope then only a single line will be loaded unless the pull is straight and direct.
Post by Rich H » Tue Mar 28, 2006 2:56 pm
Suppose so, hadn't thought of that! :o
A pulley arrangement would be easier on the rope too. But that is getting a bit complicated..... :)
Post by Stephen » Tue Mar 28, 2006 3:13 pm
I was thinking of a bar to provide jacking point and spread the load with an eye at either end. Carry a length of climbing rope or sling say 3 foot long with a karibiner knotted on at either end and one clipped in the middle to float & spread the load.
When you hit the gravel then you can clip it on and unclip without any knots once you are out.
You can get climbing quickdraws for £10 with two snap krabs. if we all carry tha same arrangement then you could clip them together to provide a tow rope etc etc.
Starting to get carried away an back into my be prepared Scout mode sorry.
MacK
Post by MacK » Tue Mar 28, 2006 3:19 pm
Would climbing quickdraws and krabs be up to the loads involved in towing a car (even a light one) that is stuck in gravel?
Post by Stephen » Tue Mar 28, 2006 3:37 pm
Should be
Rates below
# Weight : 105g
# Major axis : 24kN
# Gate open : 8kN
# Minor axis : 8kN
http://www.tiso.com/equipment/karabiner ... _pack_of_5
MacK
Post by MacK » Tue Mar 28, 2006 3:39 pm
Stephen wrote:Should be
Rates below
# Weight : 105g
# Major axis : 24kN
# Gate open : 8kN
# Minor axis : 8kN
What's a kN :?
I now know;
kilonewton (kN)
a common metric unit of force, the kilonewton equals 1000 newtons; it is a force that will accelerate a mass of 1 metric ton at the rate of 1 meter per second per second. One kilonewton equals 101.972 kilograms of force, 224.809 pounds of force or 7233.01 poundals.
Thanks too; http://www.unc.edu/~rowlett/units/dictK.html
Post by ed » Tue Mar 28, 2006 3:44 pm
I think it means kilo newtons! :?
Tom
Post by Tom » Tue Mar 28, 2006 4:05 pm
ah yes.its as clear as mud(or gravel). :? Can't count but does 24kn roughly = 2 tonnes?
MacK
Post by MacK » Tue Mar 28, 2006 4:08 pm
:scratch
jamie
Post by jamie » Tue Mar 28, 2006 5:41 pm
This takes your idea on two tow hooks a step further ....
http://www.sector111.com/handler.cfm?ca ... on=product
Could some thing like this get made up?
minkypotglory
Post by minkypotglory » Tue Mar 28, 2006 6:43 pm
GregR wrote:oh, and count me in for a group buy of one of those rear towe eyes.
Greg <gravel in shoes faction>
obviously Gordens lessons went in one ear and out the other hence gravel trap :wink:
Neilp
