If no conclusion yet or any other thought from anyone else, I might test this at Tuts evening on the 6th....... and put up with the 'roof on' jibes for a few laps no doubt.
neil wrote:That was me. I'm not sure if I'm imagining things but the roof off seemed to knock a good few mph off my top speed down the main straight. Was getting just over 100 and I'm sure I've managed 110 in the past.Modena Scotland wrote:Neil
Were you driving the exige without the roof?
Were you driving alone? I've noticed slower speed during pax laps (as expected) but not as much as 10mph.....
neil wrote:Mass
I had a pax but I've had a pax before. Will need to take the roof with me next time and try with it on and off to see if theres a difference
Modena Scotland wrote:Neil, I think what Andy is saying is that you should get to more speed than you were getting before the (mortals') usual braking point. Your engine could be down on power. Does the engine feel different in any other way? I don't think "No roof" would affect the top speed at KH much anyway as the speed is relatively low.
neil wrote:Modena Scotland wrote:Neil, I think what Andy is saying is that you should get to more speed than you were getting before the (mortals') usual braking point. Your engine could be down on power. Does the engine feel different in any other way? I don't think "No roof" would affect the top speed at KH much anyway as the speed is relatively low.MassAndy G wrote:tyre pressure should just make them grip better mate, and if anything they should enable you to carry more exit speed leading to a great speed on the straights not lesser![]()
Happy to grab a pax next time and see if it feels down on go - although hopping from the Atom might not give me the most objectove view point
The engine doesnt feel any different to what I remember. Thinking about it though, the last time I had my tyre pressures far too high - wore out the centre of my rears. This time I dropped them to 22F 24R once they were warmed up. Could the tyre pressure difference explain it?
Happy to grab a pax next time and see if it feels down on go - although hopping from the Atom might not give me the most objectove view pointneil wrote:Andy
I'm pretty sure I was quicker through the bends this time - less of a queue behind me! I'll take you up on the pax offer.
Modena Scotland wrote:Your straight line speed is determined by the corner exit speed, grip level and the acceleration available. High tyre pressures could cause the wheels to spin at lower speed losing the exit speed. As Andy mentioned, the lower tyre pressures you had would have given you a better drive out of the corner. So long as your engine is giving you the same level of power, you should have reached at least the same (if not higher) top speed....... This is why I asked about the engine.
May be an idea to get a pax on a NA exige and compare the feel of the engine.
