ENGINE:
Elise 111S 143 VVC engine (56k) running Emerald K3 ECU (Mapped by dave Walker himself)
2001 Lotus Exige throttle bodies/ airbox
ITG trumpet filter
340R exhaust manifold heatwrapped
Piper cams exhaust camshaft
DVA power 8degree offset dowels
Alpha 4.3bar fuel pressure regulator
2x bosch motorsport 5/6 bar fuel pumps (swirl pot fitted)
oil catch tank
Landrover remote thermostat kit
Mocal 24 row oil cooler kit
TRANSMISSION:
PG1 C4BP (rover C4BS) gearbox rebuilt with steel caged diff bearings and torsen limited slip diff (LSD)
PTP ultralightweight flywheel
AP Racing clutch kit
£1900 delivered.
This will come as a complete unit with everything above excluding Emerald K3 ecu, software, manual etc.. These will be an extra £500 (K3). I will however supply the Emerald MAP for the engine if you have your own ECU.
The wiring loom for VVC/ Emerald, remote thermostat, catch tank etc etc are all included in the package.
