Azure S1 1998 all required upgrades (1998) £7k *SOLD*
Post by Sanjøy » Sun Jul 06, 2008 10:44 pm
1998 "R" Lotus Elise S1 Azure Blue. Lots of receipts in the folder headliners below. Owned this car since 2000 and it is time for a change. Going to be gutted to see it go. Active Lotus forum user so lots of history of this car and myself available online. No point mincing words when if comes to Lotus cars so give me a shout if you have any questions.
Had the car on the corner scales and it weighed in at 747kg with full tank of fuel, skoosher etc.
11 Months road tax and 12 months MOT remains, just had a "B" service.
The car has ~79k on the clock but <30k on this engine, not had it on the rollers but it keeps up with other S1 special editions.
##Misc
Airhorns 2006
Sony tweeters 2003
Kenwood MP3 head unit 2002
Red clutch pipe replaced
Radiator 2006 (prev pin hole leak)
New battery 2002
Alloy window winders
4 * tyres Jun 2008 (prev P0, SO2, SO3, T1s & T1R)
##Exterior
Spare mesh rear window
Nose stonechiped - resprayed nose 2002
2 * chips in left rear flank
1 * dink in left rear wheel arch
2 * new headlights 2007/8 (prev corroded)
New windscreen 2006 (cracked)
Towing eye upgraded 2007 (prev corroded)
Drivers lights
##Brakes
OEM MMC (Metal Matrix Composite)
##Suspension
S2 suspension fitted 2004
Front springs VX220
Rear springs S2
##Engine (bought from Plans Motorsport 2003 with 20k on it)
Mike Satur head, ported and gas flowed
Big valves
VVC cast Plenum chamber
Alloy 52mm throttle body
K&N cone filter
Changed the cam belt at install in 2003
##Exhaust system
Stainless steel Janspeed manifold 2005
Stainless steel Janspeed cat replacement pipe 2004
Stainless steel Janspeed exhaust 2004
##Servicing
Dick Lovett
Lackside Engineering
Steve Williams
DB Motorsport
Jude Performance
