2 X Rear S1 Elise Rimstock Wheels, decent condition some marks from removal of wheel weights but minimal Kerbage £80 Each £150 for the pair
1 x Front Rimstock, Has a good scrape on it but I have repaired and balanced up worse in the past- needs a refurb though £35
AP 295mm Discs, brand new in the box, £300 I can supply these with bells and std calliper spacers for £500 or (£200 on their own) Eliseparts are £603 inc of VAT for identical products
2 No Under 500 Miles front callipers – removed from a New Exige S (2 Pot) £200
1 No Black Std Front calliper £75
1 No Red Front Caliper- in need of a refurb but was working fine, just looks a bit scruffy £50
1 195/50/15 Advan neova With 7mm tread £45
1 225/45/16 Advan neova with 6mm Tread £45 or £80 for the 2
2x Front A048 tyres 195/50/15 ~60% worn £75
1 x S1 Elise OZ 111s Front Wheel V Good condition £120
2x Front A048 tyres 195/50/15 ~50% worn £60 - these may be flatspotted from sitting over a winter but you can try pumping them up and taking for a quick thrape, if they are scrap I will do a full refund
1 No Rear calliper, seals etc are fine £75
1 No Rear calliper, could do with a rebuild as the rubber piston seal has been nipped, I never noticed any reduction braking performance though £30
1 S1 Exige Vented motorsport engine cover single skin fibreglass in white gelcoat £100
1 S1 Exige roof with Extended Roof Scoop, single skin fibreglass in white gelcoat £200
I have not done huge research on the prices so if something looks too expensive then let me know and we can do a deal, if its too cheap likewise let me know and I will put the prices up
Pics available on request
Everything’s in Aberdeen, collection preferred but can post at extra cost
