S2 Exige Wheels +Toyo 888 (+ hubcentric spacers) REDUCED
Stewart
Post by Stewart » Wed Jun 15, 2011 9:46 pm
Having sold my exige I now have a set of 4 "Y" Type S2 Exige wheels surplus to requirements. I purchased them used from a fellow SE'r.
They are in good condition with no scrapes or dings. There is a bit of light surface scratching but this seems to be the norm for exige wheels. One of the rears has a few specks of what appears to be white emulsion but only noticeable if you have a close look.
They come fitted with nearly new black Lotus centre caps.
The tyres are Toyo 888. The fronts have between 3.5mm-4mm across them although the rears are track use only - 1.6mm-2mm.
These are pick up only. I would be willing to meet say up to 40 miles away from Cupar if that helps.
Looking for £700. Please PM if interested.
This is an ideal opportunity to have a set of tyres on for the road and save your 048s for the summer or track days.
Will also fit a K Series S2 Elise with a set of unused hub-centric spacers that I will also include for an extra £50. These cost £90 from Eliseparts
Front 1
Front 2
Front Close Up (typical light surface scratching)
Inside of Front
3.5mm-4mm tread across both fronts
Inside rear
Rear 1
Rear 2 (with a few paint specks)
Rear tread - track use only 1.6mm-2mm
Stewart
