Draught Beer
k12chu
Draught Beer
Post by k12chu » Fri Aug 31, 2012 9:15 pm
For Sale: Draught Beer Equipment. (Will fit into the kitchen cabinet)
The manufacturer does not sell this product to the public, so these come up for sale quite rarely!
I am looking for £575 ono.
All you will need is a keg and the CO2 cylinder to get it up and running.
The 2 connectors on this one are for Cobra & Kingfisher beers. You can connect any other keg if you have a suitable connector.
This cooling unit is quite a rare one. The ones you find around in the market can connect 1 or 2 kegs, but this one can connect upto 4 different kegs.
Now the bad news (well kind of), while taking the photos, I dropped the kingfisher tap and it broke exactly at the tap. A bit of superglue will fix the job (if you can fix it, well done, if not just bin it). This photo was taken just before I dropped it.
The beer taps are illuminated.
The adapter can connect upto 6 different taps at the same time. During the fall, the adapter also took a tiny impact so you might see a small crack on the left side. Soon after, I connected the Cobra tap on to the adapter and it works fine, so it is just a small superficial damage on the outter case. It shouldn't really matter as this adapter is usually fixed under the table surface where it conveniently hidden.
The draught beer equipment is complete with all pipes (insulated), valves, guages connectors etc.
