Full set of 4 Lotus OE winter wheels and Yokohama W-Drive tyres £480 + delivery (£50?)/ or SE pony express.
If no takers by the weekend I will list on E-bay for £550+ £50 delivery
Part no's:
Front £203.96ea http://www.deroure.com/partinfo.asp?MAK ... PBID=48806
Rear £203.96 ea http://www.deroure.com/partinfo.asp?MAK ... PBID=48814
In good clean condition with no curbing, one front has slight chip on one of the spokes.
Fitted with Yokohama W Drive tyres in sizes recommended by Lotus Fr: 185/65/15. Rear: 205/60/15 (£300 approx for full set new) there is 6-7 mm of tread left on both fronts and rears.
These transform the car in cold weather and with the mid engined layout of the Europa or VX make light work of snowy inclines with the cars ground clearance being the only limiting factor.
The centre caps were not listed by Lotus and I couldn't get the right size to fit, so caps with black and silver stick-on Lotus logos are glued in place but can be easily removed if needed.
Please note as the wheels are 15inch they will only fit cars with the standard 280mm brake discs, if you have larger discs there is insufficient clearance.
Pictures available, PM for details.
Winter wheels and tyres for Europa or VX -SOLD
