Various parts - S1 & S2 Elise, Classic Mini & MG TF
Post by woody » Thu Oct 23, 2014 1:14 pm
Having a clear out of various car parts, most are listed below, but there are a few I need to dig out including MK1 mini front & rear screens & an S1 elise steering wheel.
Uprated Land Rover freelander type K series Oil rail with oil strainer. Fitted & run for 10 minutes max, surplus to requirements. Bought new from Partco as a separate item – this is not one of the oil rails that comes with the Chinese Gasket kit - £30
Elise/Exige/Europa/VX Green Stuff Pads, all models except V6. Barely used pads, came with a set of rear calipers I bought - £10
K series S2/MG TF 6 stud exhaust manifold. Superior flowing item to the standard S1 manifold. The downpipe flexi was damaged on removal and will need to be replaced (hence not pictured) but this is a common failure on K series manifolds - £30
K series S2/MG TF 160 VVC Cat. Internally in good condition, better flowing item than that fitted to the lesser powered models - £30
1960ies Lucas Spotlamp, similar to those fitted to works mini rally cars etc… Bought for a MK1 Mini project that never happened - £90
Classic Mini spot & fog light bar. Bar made of dural. Outer units are Bosch, inner are Hella & barely used but circa 14 years old - £40
MG TF Front Right Hand Side (Aft looking forward) headlight. In good condition with all mounting lugs intact - £40
