Steel caged B4bp ratio gearbox with Torsen B LSD
Dan22h
Post by Dan22h » Thu Nov 27, 2014 10:28 pm
For sale I have my pg1 gearbox with b4bp gear ratios/final drive, it has the slightly longer 5th gear fitted which is ideal for any form of distance driving. the gearbox was built under 1k miles ago using a brand new set of steel cage bearings and seals aswell as a Torsen B LSD from a rover 620ti. I'm only selling due to engine failure so I'm now collecting parts for a k20
please note that the gearbox does not have b4bp written on the housing as it was made using a custom gear set, the 1st, 2nd and 5th gears being brand new at the time along with matching synchros.
Ratios are as follows;
2.923, 1.750, 1.308, 1.033, 0.765 with 4.200 final drive
I should also add that the gearbox feels great to drive with, it engages gears perfectly with zero crunches or whines etc
Looking for £650
