Car was purchased 3 years ago in denmark where it was used in the swedish gt series. First two years it was used for 3 track days in total.
Upon purchasing it, I fitted GT4 spec brakes which are 380mm alcon fronts and 355mm rears. I then completed with success in 3 Races in the scottish modified saloons championship at the beginning of the year, laid the car to rest for a while due to a heavy work schedule before moving to the Nurburgring where it completed 8 laps on DN 16 trackday to test the cars suitability on the track. The car has had fluid changes before every use including engine, gbox and diff.
The rest is standard GT4 spec as follows with upgrades as listed
Engine:
• Front-mid mounted Ford 3.5 litre V6 300hp (340bhp stage one engine removed for rebuild and available)
• Upgraded Carbon air intake system
• Quaife 6 speed sequential in-line gearbox with integral oil cooler
• Ohlins adjustable dampers recently refurbished and modifed by ohlins germany
• Front brakes - 6 pot calipers/380mm disc
• Rear brakes - 4 pot calipers/355mm disc
• ATB differential
• AERO front bumper with optional canards
• Carbon rear wing
• MOTEC ECU and data logging system
• Weight - 945kg
• FIA approved fuel cell and roll cage
• Heated windscreen
• 80 litre fuel cell with dry-break system
• 10” rear wheels
• Endurance heat shielding
• Air jacks
•Additional Geartronics Paddleshift System (£4000 optional extra)
-Driver Recaro Carbon Seat
-Passenger Lico Ginetta Seat
I also Have the following spares available by negotiation;
Stage 1 engine delivering 340 bhp
longer differential (3.4 Final Drive)
Springs
Assorted Wishbones (some damaged)
spare hub
Spare used radiator
Spare rear clam
spare front clam
spare rear lower clam
assorted clutch packs used
assorted wheels and tyres
dash
tunnel
ginetta works p1 race suits 2 sizes used
lico ginetta seat used
original mirrors
high flow cats
car cover
oil cooler (diff or gbox) used
Car is currently located in germany but delivery can be arranged in europe.
P/X Welcomed, ideally looking for a road legal track car ie lotus 211 or Exige race car
Pm For price options
