Elise SC 260bhp - £20000
Post by Mike Scib » Thu Aug 23, 2018 9:13 pm
Elise SC 260
For sale is my Elise 260 which I have owned for over 3 years which is a testament to how special this car is from someone who normally changes his car every year or less!
The car started of as a Elise 111r and then was extensively turned into a 260bhp Supercharged Elise using only genuine new lotus parts for the build. This is not to be confused with just a 260bhp remap, it has the larger M62 charger from a Exige 260/2-11 plus all of the associated parts as listed below. The car is essential a 2-11 with doors, aircon a roof and windscreen!
Full spec below of the works carried out in 2012/13 with the car only covering 20k since.
Suspension:
Full suspension refresh, bushes, ball joints and wheel bearings and all bolts (Lotus)
Wishbones blasted and repainted.
Nitron NTR 40mm Trackday Pro single way adjustable
Lotus sport adjustable anti roll bar with new bushes and drop links.
Lotus Sport track brace kit
Brakes:
Braided brake hoses
Mutol RBF600
Pagid discs
Pagid RS14 pads pads
Engine:
Upgrade to new MY 06 wiring looms front and rear inc revised headlight sub looms
Upgrade to new electronic throttle
TRD airbox and filter
New M62 supercharger
New manifolds swan necks, engine mount, brackets, oil feed pipe work etc.
New Light weight intercooler pipework (Pro Alloy)
New Twin oil coolers, sandwich plate and hoses.
New high capacity fuel pump
New 440cc injectors
New injector seals and manifold gaskets
New T4E level 3 ECU with 260bhp map from Factory
New ECU mounting plate
Hanger 111 high capacity intercooler
Lotus 2-11 intercooler cold air shroud and ducting to side vents
New Lotus 2-11 intercooler mounting brackets.
Thermo-Tec heat barrier
Thermo-Tec Gold Anodised heat barrier
Moroso baffled sump
Proflex upgraded engine mount inserts.
Pro Alloy triple pass alloy radiator
2ubular GT3 back box
Engine cover modified for extra cooling
Chassis:
New Lotus AC condenser and pipe work.
Heater resistor pack upgrade
Lotus Sport Probax seats with Harness holes
Scroth harnesses (drivers side only)
Harness bar
New Soft top
Team Dynamics 1.2 alloys
AD08r tyres (6-7mm all round)
260 decals (Lotus)
Elise parts rear diffuser and panel eliminator kit.
More details;
Year - 2005
MOT - 30/4/2019
Mileage - 55000
Private plate - T26 CUP (will remain on the car)
The car was classed as a cat D back in 2012 for rear clam damage and a bent wishbone. No chassis damage which made it the ideal candidate for this build. Email me for full build details and more pictures.
If you have any questions please do not hesitate to ask.
Located in East Kilbride.
£20000
Mike
