VX220 Supercharged Lightening Yellow
Haston
Post by Haston » Mon Jun 17, 2019 10:00 pm
It has come time to sell my pride and joy due to a change of circumstances I have owned it for around 4.5 years.
It’s done around 2000 miles since the Supercharger kit was fitted.
Lightening Yellow No65
HPI Clear
99,500 miles
14/06/20
Yellow hardtop in bag
Private reg is not included it will be sold with MA02 GZJ
2 keys
Since buying the car I have done the following:
Engine
• Brand new old stock VSE
• Pre cat removed
• Cold air intake fitted
• Pro Alloy Charge cooler rad fitted
• Alloy radiator
• SL silicone top hose (with the better bleed nipple)
• Both Timing Chains Changed (GM parts)
• Waterpump changed (GM Part)
• New Studs and nuts fitted to the exhaust manifold
- Supercharger Kit (Stage 2)
• M62 Supercharger from LSJ
• LSJ Throttle body
• Blue z20let injectors
• ZZP Dual Pass kit for Charge cooler system
• Pro Alloy Chargecooler radiator
• Alloy catch tank
• OBDTuner (Dutch ECU Software, software key will be provided)
Chassis/Suspension
• Nitron Street series coilovers
• Elise Parts rose jointed toe links
• Uprated hub carrier bolts
• Yellow Powerflex engine mount inserts (Front/Rear)
• Engine mount changed (N/S) I have the O/S.
• New pair of front tyres for MOT
• New handbrake cable (Elise Parts)
• HELL Braided brake lines
Exterior
• TAT style rear diffuser
• New Brembo discs and red stuff pads on the front
• Fogs removed
• V removed
• Anti rattle door pins fitted
Interior
• Alcantara covered door cards
• Carbon door handle surrounds
• Carpet fitted to floor (sides not fitted)
• New JBL speakers fitted
• Window rattle fix done
• Leather covered centre console fitted
Spares
• Fog Lamps and Brackets
• Grill V
• Carpet sides
• Spare set of dash clocks
• Spare Cam cover
• Window surround seal
• O/S engine mount
• Spare shorter SC belt
Bad Points
Mainly bodywork
• Small marks in the paint and some chin rash.
• Small crack on rear clam just below numberplate, underside cracked but not visible when diffuser fitted. Someone reversed into it at work and drove off.
• Crack behind front numberplate
• Crack on the O/S rear wheel arch.
• Other marks around car.
• Hardtop has one bolt stuck in it can still be fitted.
Do not let the bodywork imperfections put you off the car is still presentable.
Link to my build thread showing the work done
http://www.vx220.org...ndnice-day-car/
Please feel free to contact me to view or if you have any questions.
£10,750ono
Vauxhall VX220 LY No65 Supercharged
Focus ST250
Austin Mini Cooper 69
Triumph Street Triple 675R
