K series ported head and cams etc
Post by rossybee » Tue Jan 30, 2007 2:02 am
Elise no more :roll:
'72 Alfa Romeo Giulia Super
'07 Aston Martin Vantage
:blackeye
dr al
Post by dr al » Thu Feb 01, 2007 4:57 pm
Is that including cams??
if so which ones
and who did the porting!
cheers - not sure if i'm interested, cos i WAS planning on waiting a bit before getting more power, but.........
A.
Post by rossybee » Fri Feb 02, 2007 7:53 am
Just got a reply:
Includes Piper 285 cams and caps etc
Work was carried out by A and W engines in Chester who have some killer K series heads, Powderpuff has one and a friend of his is a K series engineer at Rover and is well impressed with their work.
Its a full port , its a head for that if I'd put it on a 1900 block would have got me above 210 , above 190 on 1800 and forged etc
BTW, Powderpuff is a Caterham guy who does sprints etc :wink:
Hope this helps :)
:blackeye
Post by robin » Fri Feb 02, 2007 8:07 am
If you're looking to put this on an elise you'll need direct to head throttle bodies, and airbox and an ECU or you'll need to swap out the 285H cams for something tamer and then you can keep the standard setup.
I would say this is doable in an S1 and harder in an S2.
Post by rossybee » Fri Feb 02, 2007 8:13 am
I did wonder if there'd be any Caterham to Elise complications.....
Thanks for the clarification Robin :wink:
:blackeye
dr al
Post by dr al » Fri Feb 02, 2007 12:26 pm
cheers. - probably not ideal for my needs on the S2. - i'm really not keen to go DTHTBs and monkey with the boot.
thanks anyway, guys!
A.
Post by rossybee » Sun Feb 04, 2007 8:39 am
:wink:
:blackeye
