Unused Vaude Monolith tent for sale at less than half RRP. Takes up very little room in an Elise.
Only £100 plus £10 postage via Parcelforce
This tent was designed for comfort! The twin hoop design gives a total ground cover of 3.8m x 2.6m with the users sleeping across one end and the other half for storage. The huge storage area has enough room for 2 bicycles or other equipment. This tent is designed to the strongest possible shelter at an absolute minimum in weight and stuffed size for the backpacker.
Features
Seams: All stitched seams are taped on the inside using sealant tape applied under heat and pressure to give a strong waterproof seam.
Mesh: The mesh fabric favours the longetivity of the polesleaves.
Cords & Zippers: Lightweight polymide webbing designed to withstand high tensile strength is used together with abrasion resistant cord. Zippers are particularly solid to the horizontal tension.
Outer Tent: PU Coated UV Resistant Fabric with a 5.000 mm hydrostatic head
Inner Tent: Breathable Light Weight Polymide
Floor: PU Coated Polymide Fabric with a 5.000 mm Hydrostatic Head
Poles: Elasticated Aluminium 75 T6 Alloy
Weight: 4.8Kg
Dimensions: 380 cm long by 266 cm wide by 115cm
Cost new £228
http://www.upandunder.co.uk/eshop/catal ... ion_ID=181
