Anglesey April 11th 2009
Re: Anglesey April 11th 2009
Post by mckeann » Sun Apr 12, 2009 11:20 pm
robin wrote:What a shed :-) It does seem implausible, but we could reproduce the problem at will when Sanj popped over - then I disconnected the oil temp/pressure (which is it?) sensor (the thing that prevents VTEC engaging), but of course we also pulled off the stupid elephant pipeage as part of removing the engine cover. Car immediately behaved itself, but of course would not go into VTEC. I was suspicious about the sensor or VTEC being responsible for the problems, so reconnected it, and the car still runs fine. Tie wrapped the shorter intake pipe somewhere around where the rear wheel arch would have been, removed the pipeage from the engine cover, job done.
It sounds fishy until you realise that the pipe was doing at least 2 if not 3 180 degree turns, all squished into a small space, and is heavily worn such that the rubber is flapping loose form the steel coil wire. Pretty sure it must be possible at certain air speeds to collapse the rubber such that there is nearly no air flow (try sucking air through a balloon if you don't believe me). VTEC probably a red herring.
Sanjoy did mention the hose to me, and i fobbed him off, as i assumed that if it could get enough air at fullthrottle, it'd easily get enough on part throttle, but as i said to Sanj, robin is almost always right about these things :wink: Glad its all sorted. and it really is a shed.
Post by Sanjøy » Sun Apr 12, 2009 11:46 pm
Take that back or else I will retract my request letter of sponsorship to Ginsters :wink:
Post by campbell » Mon Apr 13, 2009 1:24 pm
robin wrote: (try sucking air through a balloon if you don't believe me)
but watch you don't suffocate in the process!
Post by robin » Mon Apr 13, 2009 5:24 pm
If you do suffocate in the process, you're too stupid to live anyway ;-)
Post by Sanjøy » Mon Apr 13, 2009 7:13 pm
Iddon's theory of evolution (c)
Post by campbell » Tue Apr 14, 2009 12:38 pm
Was still in kiddie supervision mode there ;-)
Post by robin » Tue Apr 14, 2009 1:31 pm
If you're too stupid to not know not to give your kids balloons to pay with, you're helping evolution make up for lost time ;-)
Post by campbell » Tue Apr 14, 2009 1:33 pm
We are lenient and let them keep the ones that remain inflated ;-)
Which generally isn't for long...
Wallsy
Post by Wallsy » Wed Apr 15, 2009 12:15 am
Post by mckeann » Wed Apr 15, 2009 6:05 pm
Wallsy wrote: Image
See sanjoy, this is what i meant when i talked about apexing :wink:
Post by Scotty C » Wed Apr 15, 2009 6:55 pm
i did notice.
