Body shop Pics (NLC)
Post by simon » Mon Nov 20, 2006 11:37 pm
mac wrote:I would imagine that the most likely occurance of a high speed "off" would happen on track where the harnesses would be used.
Maybe a higher speed off would happen on track but take the speed of another car in a head-on crash like Stuart's into account and you've got a much worse accident than hitting a tyre wall.
Blaque
Post by Blaque » Tue Nov 21, 2006 7:58 am
To be fair, I have previous compression fractures to L2 and L3 from hitting a pickup truck 18 years ago. And now a fracture to L1, this may be just a weak area for me.
I can see the problems with harnesses, but for me it's that snap back into the seat in a collision that damages the back, and done up properly this would prevent it. Maybe CG Locks are what I should be looking at?
Post by Gareth » Tue Nov 21, 2006 9:07 am
I've got both in the Exige
Post by dezzy » Tue Nov 21, 2006 10:28 am
I'm definitely going to get CG locks for when I start tracking the car, in advance of considering harnesses. I felt a big difference with the CG locks in Andy's and Ed's cars, compared to when I went out with people who didn't have them and I just had a standard seatbelt. My fat ass was sliding all over the place! :lol:
RDH
Post by RDH » Tue Nov 21, 2006 1:36 pm
dezzy wrote:I'm definitely going to get CG locks for when I start tracking the car, in advance of considering harnesses. I felt a big difference with the CG locks in Andy's and Ed's cars, compared to when I went out with people who didn't have them and I just had a standard seatbelt. My fat ass was sliding all over the place! :lol:
i've got a CG lock in the drivers seat and notice ahuge difference to the normal seatbelt - cant comment on harnesses tho!
Caterham Roadsport 190
Tesla Model 3 LR RWD
Post by Rich H » Tue Nov 21, 2006 1:45 pm
I love my harnesses, but the pax one is annoying as my pax (Unlkes sit's the g/f can't normally cope....
I personally would not have a problem with the increased lever arm debate, afterall the seat is glass fiber and that is all the seatbelt seems to mount into...
PS Check your seat mount points! Mine were loose (Again!) even after being threadlocked last time (6 months ago)
Post by GregR » Tue Nov 21, 2006 2:14 pm
Blaque wrote:To be fair, I have previous compression fractures to L2 and L3 from hitting a pickup truck 18 years ago. And now a fracture to L1, this may be just a weak area for me.
Interesting debate here on the likely effect of harnesses. I do a lot of RTA work, and a lot of that has significant emphasis on the interraction of seatbelts (or more properly, lack of them) and the injuries sustained. Are you saying the wrist injury would've been prevented by the harness (I doubt it) or the back injury? All depends on the type of fracture (wedge, compression etc) and the 'mechanics' of the injury. IMHO, harnesses would likely prevent an injury further up the spine (e.g. thoracic or cervical, your C- or T- prefixes) given the upper body is held closer to the seat. With a lumbar injury (correct me if I'm wrong here Novice!) its likely to be a low impact, e.g. getting rear-ended or the car coming off the road with a thump. The restraining part of an inertia reel is more or less the same (IIRC) as the harnesses over the pelvic area so doubtful if they would have made a difference with the L-spine injury.
All IMHO of course :)
Post by robin » Tue Nov 21, 2006 2:35 pm
Blaque wrote:I can see the problems with harnesses, but for me it's that snap back into the seat in a collision that damages the back, and done up properly this would prevent it. Maybe CG Locks are what I should be looking at?
There are no external forces pushing you back into the seat at the end of an accident (or any other time, except for the tiny acceleration force from the engine). [OK, I'm going to retract that, a bit, if the car is spinning then there will be some centripetal force from the seat into your back, but that would be while it was spinning and wouldn't reverse when you come to a stop; what I wrote originally is true if your car isn't spinning, though].
I can only assume that the snap back into the seat happens because of elasticity in your spine (and the muscles that you clench when you want to stop yourself going forward). When your body comes to a rest suddenly you cannot stop clenching quick enough and you slam yourself back into the seat.
The reason you cannot stop yourself travelling forward is not really the give in the belts (travel while the inertia lock catches, stretch in the actual belt, movement in the anchoring points) but rather the mass of your head bending your body forward.
With lap belts, the whole spine can bend from the base all the way to the shoulders, so the effort is "shared".
With harnesses (assuming they're fitted properly), your shoulders will remain pinned to the seat and it's only your neck that will bend - so much so that you can disconnect it from the base of your skull!.
So you add a HANS device to limit the travel of your skull as well. At that point your brain tries to escape out of your nose, because nothing is stopping it, even though your skeleton is held tight :-)
So I think it's horses for courses - for road driving at road legal-ish speeds, a 3-point belt probably offers best all round protection, though will in some cases leave you with more injuries than a multi-point harness, it generally won't leave you dead :-)
Post by simon » Tue Nov 21, 2006 8:25 pm
GregR wrote:Are you saying the wrist injury would've been prevented by the harness (I doubt it) or the back injury?
I assumed the wrist would have been caused by holding on to the steering wheel during impact. There's a reason you often see racing drivers let go of the wheel!
Blaque
Post by Blaque » Tue Nov 21, 2006 8:31 pm
Yep! and the left shoulder has more freedom to move forward, and so more momentum. That's why I was thinking harness
Post by Stephen » Tue Nov 21, 2006 11:19 pm
Stuart I have something simmilar but worse on my arm. Yours looks like a really goood job to me :thumbsup to the doc who did it.
Hope you get better soon
S
Post by renmure » Tue Nov 21, 2006 11:33 pm
All interesting stuff. I did a 2 yr MSc reseach degree in Bioengineering covering all aspects of this sort of trauma. 10 years on and I remember more about what I had for lunch 11 years ago :oops:
Jim
