Where for a new K series
GilesM
Re: Where for a new K series
Post by GilesM » Wed Jul 04, 2012 3:56 pm
steve_weegie wrote:
GilesM wrote:
Shug wrote:That will do fine - you dont need too much force to clamp them, especially if you make sure you're always pushing the piston downwards, towards the crank when you're connecting up the bearing caps. The blue hylomar sealant for the liner bottoms doesnt set solidly either, so isn't mega sensitive to movement during assembly.
Thanks Steve, I have a good bit of plastic pipe that will do the job perfectly.
GilesM
Post by GilesM » Wed Jul 04, 2012 4:06 pm
Next subject to confuse is the sealant for bearing ladder to sump and bearing ladder to block, the rover manual recommends GUG705963GM, is this the best thing to use, or is there a better alternative?
Also for the crankshaft oil seal at the flywheel end GAC 8000 is recommended, is this the best thing, if so, does anybody know where to find the stuff.
And finally for the cylinder liners GGC 102 is recommended, is this the stuff to use and again, any recommendations where to get it from.
Thanks
Giles
Post by Mikie711 » Wed Jul 04, 2012 4:10 pm
First one is Loctite 574 (ignore what it says on the tube, it is the same stuff)
Second is Loctite 5910
and last is hylomar blue.
Mike
GilesM
Post by GilesM » Wed Jul 04, 2012 4:19 pm
Mikie711 wrote:First one is Loctite 574 (ignore what it says on the tube, it is the same stuff)
Mike
Thanks Mike
roadboy
Post by roadboy » Thu Jul 05, 2012 6:54 pm
For the cam/crank ladders and sump I use some GM sealing compound. Does the same job as Loctite 574 at a fraction of the price and you can buy it from any Vauxhall dealer. I'll post the part no. in the morning.
Hylomar Blue for the liner shoulders and any good RTV will do for the crank seal.
HTH
Dan
SPS Automotive
Independent Lotus Specialists
GilesM
Post by GilesM » Mon Jul 23, 2012 5:33 pm
Head has come back from Sabre heads, looks fantastic, hopefully things will start going back together very soon.
Giles
Post by campbell » Mon Jul 23, 2012 11:45 pm
Picture please :-)
GilesM
Post by GilesM » Tue Jul 24, 2012 9:13 am
Not the best pic of the renovated head due to plastic packing and the flash, but you get the idea, hopefully the before and after pic are obvious 8)
Post by campbell » Tue Jul 24, 2012 11:34 am
A work of art.
pete
Vexatious Litigant
Post by pete » Thu Jul 26, 2012 11:50 pm
campbell wrote:A work of art.
+1
'99 - '03 Titanium S1 111S.
'11 - '17 S2 135R
'17 - '19 S2 Exige S+
'23 - ?? Evora
GilesM
Post by GilesM » Thu Aug 09, 2012 9:13 am
With help from Stuart and his machines I now have wonderful looking top of the cylinder block, and a spot on stand proud for the cylinder liners, just waiting for one grooved main bearing that was on back order from Lotus, and hopefully I can start putting things together.
Gils
