Cadwell with LOT on 16/2/06
Strictly for tarmac whores
Post by robin » Wed Feb 07, 2007 10:53 am
At present I have no idea - it might be late :-(
Tom
Post by Tom » Wed Feb 07, 2007 11:16 am
nightmare.... i expect kenny and i will share, then you can sneak in whenever. will let reception know to expect you also.
1995 Volvo 940SE Estate
Post by ed » Wed Feb 07, 2007 11:35 am
Tom, remind me to give you the confirmation documents to take with you! :)
Post by kenny » Wed Feb 07, 2007 1:36 pm
Tom wrote:kenny, i'm not fussed either way, but we may as well go the more direct route ie A1 etc. the esso ok at hillend.?
Direct route for me, 6 hours of driving ahead of us so not really in the mood for country roads in the dark.
If its just us two Dreghorn Shell suits me best as a meeting point, I can try to be a bit earlier if I can. I'll give you a call when I am setting off from Glasgow (pm me your mobi number) that way we can maybe get an early start.
Post by ed » Tue Feb 13, 2007 2:57 pm
Yeah direct route works for me, especially if theres rain. Think D and 4mil are planning on heading down there together. What time are you thinking of leaving Paul?!
Post by ed » Tue Feb 13, 2007 3:49 pm
I finish at 12.15 so anytime after 2 ish would be good with me! :D
Post by mckeann » Tue Feb 13, 2007 9:45 pm
i probabaly wont be going any more as my car is playing silly buggers (wont engage vtec) so no point heading down with a duff car
Post by ed » Tue Feb 13, 2007 10:48 pm
Is it something that for example Dan could fix?! You could always drop in on the way down?! :idea:
BigD
Post by BigD » Tue Feb 13, 2007 11:08 pm
mckeann wrote:i probabaly wont be going any more as my car is playing silly buggers (wont engage vtec) so no point heading down with a duff car
Ah, that's a bugger. :(
Post by tut » Wed Feb 14, 2007 12:08 am
Neil
I have a K-Pro if that would help.
roadboy
Post by roadboy » Wed Feb 14, 2007 2:11 am
Hi Neil,
Sounds like its probably a temperature or pressure sensor fault.
Give me a bell if you like. Would be a shame to miss out on the day.
Dan@JPS
SPS Automotive
Independent Lotus Specialists
Post by mckeann » Wed Feb 14, 2007 3:02 am
Dan, do you have the equipment to hook up a Kpro to do a diagnostic check?? Also, do you have spare senors in stock??
My current thinking is that it isnt the water temp, as that causes the limiter at 5000rpm when cold. It does work when cold, and i can go above this when hot, so all seems well.
Its not the gearbox speed sensor, which also limits the car to 5000rpm, and again, i can get above this.
The cam phasing and low oil pressure switches would both give the symptoms i am seeing, but i have checked the switch end and all seems fine. No corrosion or water.
There is a touch of green mould (verdigris) on a couple of wires that go into the ecu plugs. I think its more likely that these are affecting the signal from the sensor rather than the sensor itself, although this is pure guess work on my behalf.
Dan, if you have the software to hook up to my kpro to do some diagnostic work, and if you have time on thursday, then i may well head down. If we can sort it then i will go on and do the trackday, if you cant, then i can head home.
roadboy
Post by roadboy » Fri Feb 16, 2007 12:19 am
Just noticed this post Neil, sorry. Glad you got it sorted anyway. Make sure you get a cover made up for the relays and the ECU.
Dan
SPS Automotive
Post by campbell » Fri Feb 16, 2007 12:23 am
BTW, not 100% sure, but a colleague of mine might be heading to Cadwell for this session in his Caterham R400 crazy something or other, I think.
Name's Stuart Bampton, top bloke, if anyone does come across him, say hi from me and show him the customary SE friendship and camaraderie!
