340R Colin's Honda Conversion
andyc
Re: 340R Colin's Honda Conversion
Post by andyc » Sat May 22, 2010 4:31 pm
Good work Alan. :thumbsup
Fat drive shafts for Colin I assume?! :damnfunny
(Oi....Colin....you going to the curry night? I might drive so can give you a lift.....might drive!!)
Blue S2 (sold to the plumber)
Seat Leon Cupra Commuter Car
Post by tut » Sat May 22, 2010 5:01 pm
What are your plans for the spare driveshafts Alan?
Gourlay83
Post by Gourlay83 » Sat May 22, 2010 6:25 pm
I should have made myself clearer, its Starks mistake. No big deal, they had 4 boxes of Driveshafts. 2 for me and 2 for antoher customer. He managed to mix them up so we have one uprated and one standard. :damnfunny
Opened up the boxes last night (12.00) muttering WTF :scratch A courier will swap them around on Monday
Have to say they look great, much chunkier (sorry, best word I could think of) and heat treated etc ..
Alan
Gourlay83
Post by Gourlay83 » Sat May 22, 2010 8:23 pm
Ready for lifting in tomorrow, have to stop for a break tonight.
Alan
Post by tut » Sat May 22, 2010 8:34 pm
Completely different than the Link-up ones Alan, but certainly look the works.
Post by Mr Momo » Sat May 22, 2010 9:14 pm
Great job Alan - always impressed by the skill and patience shown on here.
How's the welding on the shorter left hand mount - looks a bit light compared the mount used on the g'box - do you think you'll have to keep an eye on it ?
Looking forward to hearing it.....
Emira - Volvo spec
Gourlay83
Post by Gourlay83 » Sat May 22, 2010 9:36 pm
Mr Momo wrote:Great job Alan - always impressed by the skill and patience shown on here.
Its welded all the way round and braced underneath, shouldn't be a problem.
All the mounts are over engineered in my opinion, If you did actual stress analysis you could probably remove half of the material.
Alan
Gourlay83
Post by Gourlay83 » Sun May 23, 2010 10:15 pm
Engines in with no problems at all.
Manifold Fits perfectly with no madifications to Bulkhead and throttle body points away from the expansion tank. Perfect for the Air Filter housing etc...
Only took 6hrs, thanks for the help from Mike (Honda's are Ace) Stout. Mike doesn't post on technical but did say Honda Conversions are the way forward, a huge improvement to the boat anchor rover p*sh. Cheers Mate :cheers
Have exams this week so won't be able to do much to the car, so consider this a week break.
Alan
MacLotus
Post by MacLotus » Sun May 23, 2010 10:32 pm
Looking Good!!! Great angles on the pictures Alan. Very nice!
Ken
Gourlay83
Post by Gourlay83 » Sat May 29, 2010 11:10 pm
Another day of working on the Conversion.
Due to the Extra Power I felt it was best to upgrade the fuel Pump. Liked the Idea of an OEM like fitting of the Walbro so went with that. OEM my arse, it fits inside the original Fuel Pump Assembly (Just) but you have to modify pretty much everything. It should do the Job but not impressed.
All thats left is to build up the driveshafts, wiring and tie up a few loose ends. Struggling to juggle Work, College and Conversion but I will get there.
Thanks to Mike for the help and sorting out the wheel bearings, makes my life a bit easier. :cheers
Alan
Jacobite
Post by Jacobite » Sun May 30, 2010 1:18 am
Looking good Alan Thanks for taking the time to take pics and post them
cheers :cheers :thumbsup
H8OAG
Post by H8OAG » Sun May 30, 2010 10:41 am
Great thread
Hoping for a bit of video /youtube link when you fire it up
BMW Z4M40i
Range Rover Velar
2022 Spec Mini JCW
BMW R9T Scrambler Sport
Honda 250 Race Quad
Womaniser Liberty
roadboy
Post by roadboy » Sun May 30, 2010 12:10 pm
Gourlay83 wrote: Due to the Extra Power I felt it was best to upgrade the fuel Pump. Liked the Idea of an OEM like fitting of the Walbro so went with that. OEM my arse, it fits inside the original Fuel Pump Assembly (Just) but you have to modify pretty much everything. It should do the Job but not impressed.
Yeah, they're a bitch to fit and have their own limitations. Much easier and not much more expensive to fit a second pump and swirl pot then it's fully future-proofed should you want to go supercharged.
Are you going to post all the costings on this for all the people interested in the conversion Alan?
And who's doing the mapping?
Dan
SPS Automotive
Independent Lotus Specialists
Post by tut » Sun May 30, 2010 12:40 pm
Both Craig and I bought our uprated pumps from Gaz, straight replacement as it is the whole assembly, and they have obviously done their job.
Gourlay83
Post by Gourlay83 » Sun May 30, 2010 12:55 pm
Dan
Wish I had fitted the 2nd pump & swirl pot Dan, you live and learn. It will always be a N/A install but he may go for a 2.2 bottom end at some point (Same Crank but with Cosworth Pistons and Darton Liners).
Jim's making an over the top manifold and silencer (421) which won't be cheap so would prefer to only pay for one. I've uprated all the valve train so he could easily bolt a set of hotter cams and 2.2 bottom end for £2000. I had a bit of an issue with the exhaust, I had to decide to go for 1 3/4" or 1 7/8". Decided on 1 7/8" to make it future proof, so fingers crossed it won't loose too much torque.
Mapping
I will probably sort out the Fueling as it takes a fair amount of time and any idiot can do it and then leave a pro with a dyno to write the map. Haven't a clue who that will be yet. Maybe see if Corbie fancies a homer :thumbsup
Cost
Edited for Wife Friendly reading :oops:
Around the £ mark. He could have done it for a lot less but with the upgrades to the Exhaust/Engine & Driveshafts its pushed the cost up.
Alan
P.S I know he could have bolted on a Charger but I would consider it irresponsible to give Colin Murray 300 BHP. :blackeye
