NLC: Bored with a camera.
Are you shooting jpeg or raw??
What image editing software are you using??
If you shoot raw you have full control in the conversion process
and can adjust saturation, contrast and much,much more!
If you shoot jpeg then you are a wee bit more limited but it's
all up to Photoshop or whatever editing program you are using.
In Photoshop 'curves' or 'levels' will allow you to adjust contrast etc.
Andy.
Andy.
Yellow S2 Race Tech
Black Renault Trafic (with LPG conversion)
I am shooting JPEG as the Raw files take up massive space. I have a 16GB plus a 4GB CF cards, so it should not matter I suppose.andy_snap wrote:Are you shooting jpeg or raw??
Andy.
I don't have a copy of Photoshop, and My Fireworks CS3 trial has expried. I am due to do a software audit shortly, will find a need for both products!
G.
Forde Freda Campervan!
http://www.LotusEliseR.com
- David Bryce
what Andy said
also, while I shoot everything in Raw - AdobeRGB, with the D200 if you want jpgs straight out of the camera that have 'pop' use these settings:
image quality - fine, image size - large, jpeg compression - optimal quality
white balance - auto
in the 'shooting menu' change the colour space to sRGB, then in 'optimize image' go to custom then +1 sharpening, auto contrast, color mode III and auto saturation
personally I would not do any of that though, I want my images out of the camera to be 'neutral' so I can decide how I want each individual image to look
Can I add all those setting to one of the memory banks, number 2 for example? And then revert to default mode by switching memory banks?David Bryce wrote:what Andy said![]()
image quality -fine, image size - large, jpeg compression - optimal quality
G.
- David Bryce
Here is an example I took yesterday, not sure if increasing the contrast would help, was hoping to enhance the overall colours:
(Downsampled).
G.
Edit: Also, how do I avoid the trees in the background being blurred whilst keeping the forground branches in focus too? Two different shots and merge them?
(Downsampled).
G.
- David Bryce
Thats an insane difference, like a completely different photo. Haven't got a clue about F22 and Hyperfocul...David Bryce wrote:this is with just with a wee adjustment to levels and a tiny boost of saturation:
the easiest way to get the foreground and back round in focus is to use a small aperture, maybe around f22, and use the 'hyperfocul' focusing technique
G.
- David Bryce
My brain just melted:David Bryce wrote:buy a bookHaven't got a clue about F22 and Hyperfocul...![]()
http://www.dofmaster.com/hyperfocal.html
Should have got a point and shoot
Plenty freebies online...RDH wrote:David Bryce wrote:buy a really expensive bookHaven't got a clue about F22 and Hyperfocul...![]()
G.
- David Bryce
Should have got a point and shoot![]()
Like your landscape
The scale on the lens is what I used to use when doing jobs in the Navy if I was'nt able to pre focus on something (Water very hard to focus on
A good example was at Faslane where they wanted shots of Submarines as close as possible, going as fast as possible, with the mountains in the background in focus.
The cameras we used were normally Mamiya C330 twin lens reflex cameras which only had a distance scale at the side of the camera so we actually had to work out the Hyperfocal distance using a formula. We had to use a medium telephoto launch to put a bit of distance between ourselves in the Police launch and the fast approaching Submarine.
Using a telephoto lens gives you less depth of field (the distance between the nearest thing in focus and the furthest away thing in focus) so that didn't help matters and plus because we were on a boat traveling at speed we had to use higher shutter speeds to avoid camera shake which meant that you couldn't use high F numbers such as F22 to give you more depth of field. Its a wonder we ever got anything at times considering the dull weather as well.
Here is one example - must colour it in sometime
Vauxhall Astra 1.4 Sports Hatch - not as slow as my old Corsa
David, Can I ask a wee bit of advice about colour profiles? You shoot Raw + AdobeRBG. I do too. But this means that when my photos are saved as jpegs for the web (flickr or wherever) the images look washed out when viewed in a browser. What is the best way to do the conversion? Shoot in sRGB in the first place? Shoot in AdobeRGB but then work in sRGB in photoshop/aperture? Convert the jpeg? Do jpegs have any concept of colour profile or do you have to convert first, then create the jpeg? I'm confuddled.
Thanks for any advice you can give.
Graeme
