Lotus front nose badge change ?
RDH
Re: Lotus front nose badge change ?
Post by RDH » Mon Mar 24, 2008 11:53 am
meatball wrote:Don't use the screwdriver.....you'll damage the paintwork/clam......fishing line, some gloves to prevent slashed fingers and some patience!
Enjoy.....
I have a new one sitting in my kitchen but will wait til it gets a bit warmer before I set about it (with some SE help!)...... :wink:
Fishing line and a hairdryer apparently - ask Dezzy - I'm sure he changed his on the Exige?
Caterham Roadsport 190
Tesla Model 3 LR RWD
Post by jj » Mon Mar 24, 2008 11:56 am
Can I have the old one when you take it off please?
I need one for my motorsport engine cover and a wee bit of lacquer peeling wont bother me :D
Post by meatball » Mon Mar 24, 2008 11:56 am
He is the SE help I was referring to! :lol:
Hope he can bring a hairdryer....I don't have much need for one! :wink:
Post by meatball » Mon Mar 24, 2008 11:58 am
No prob.......unless J33AMA beats me to it.
Post by jj » Mon Mar 24, 2008 11:58 am
meatball wrote:No prob.......unless J33AMA beats me to it.
Your front clam is failry new so yours is probably in better nick :lol:
Post by meatball » Mon Mar 24, 2008 12:02 pm
6 months newer.....i image its the original nose badge!
Although J33AMA washes his car daily.....and twice daily at weekends.....maybe thats why his is peeling!?
:wink:
Post by dezzy » Mon Mar 24, 2008 10:50 pm
meatball wrote:He is the SE help I was referring to! :lol:
:finger
Yep . . . hairdryer to heat up the glue and loosen it a bit, then perseverance with fishing line for several minutes in a sawing action underneath the badge. Will feel like it's not going to come off, but give it time and it will.
D
russellphoto
Post by russellphoto » Thu Nov 19, 2009 2:43 pm
How much of a job is it to change the front badge on an S1 elise? Somebody has tried nicking it and it is now scratched and scraped to bits. :( Luckily they don't seem to have marked the paintwork.
Russell
2000 Elise in racing green. Soft top leaks but the hardtop is even worse!
Post by Corranga » Thu Nov 19, 2009 2:56 pm
I have a feeling the S1 is a clam off job, though I *think* I read somewhere you can do it with the clam intact if you have driving lamps - I presume the thing here is that the front grill is fixed to the clam, and you remove the driving lamp / put hand in through the hole.
Then you may want to consider putting an s2 item on (stick on) or an s1 item with the screws ground off and some sticky pads...
though obviously there are pros and cons:
Easier to nick
Easier to fit
Won't cause clam damage if someone gets over zelous with a screwdriver trying to remove it
Will just pop off
Reckon they are also cheaper...
s2 item probably weight less too :lol:
Chris
russellphoto
Post by russellphoto » Thu Nov 19, 2009 3:02 pm
Thanks for that - I'll give it a try and see how I get on.
Russell
