K Cylinder Head Helicoil Inserts in Aberdeen?!?
Re: K Cylinder Head Helicoil Inserts in Aberdeen?!?
Post by BiggestNizzy » Tue Apr 01, 2008 9:48 am
You could use a greasy Tap, cover the tap in thick grease and take half a hurn on the tap.
remove, replace grease and another half turn.
maybe worthwhile using a borascope just to check when finished
Post by Rich H » Tue Apr 01, 2008 10:28 am
A few bits of tiny ali swarf can be blasted out with compressed air. Should be ok...
c5tto
Post by c5tto » Wed Apr 02, 2008 1:08 pm
there is a head shop on the lang stracht behind belmont vauxhall next to autosonic, they have skimmed heads for me in the past, not been there for a few years so not sure if the place is still there but worth a try. they were pretty cheap aswell
2F45T4U
Post by 2F45T4U » Wed Apr 02, 2008 4:15 pm
i think the place in whitemyers industrial estate is away. Gibbs tools on king st sell helicoil kits, Falconers sells the inserts and he let me take the tool away to do it at home if i wanted. ended up not needing to but anyhoo....
just use grease to collect the swarf. you wont have much luck with hoovers or compressors to collect it. the plugs are in too deep. and i think there would be more chance of it blowing into the engine.
you could be smart and line the engine up so the inlet is open and pressurise the cylinder to try and blow the swarf out the plug hole...but thats getting a bit silly.
at the end of the day. if any swarf does get in, it will soon blow out the bores in the first secs of running, its only aluminium.
caleebra
Post by caleebra » Thu Apr 03, 2008 1:54 pm
Would that be Precision Engine Services? Saw them on a phone book listing, but no more you say? Bummer!
Had a look again last night and I can see why people wouldn't fancy it, those plugs are a loooong way down. But then I had a look at the access available to remove the components required to get the head off - nice!!! Worse than a VX/Elise? Most definitely!
Lee
[flamesuit] VX220 owner[/flamesuit]
2F45T4U
Post by 2F45T4U » Fri Apr 04, 2008 8:51 am
you will get a 2nd hand head from persley for about £25 (probably cheaper than arsing about with helicoils) , get a gasket set and you would be as well doing the job right if your thinking the head has to come off anyway.
steve_weegie
Post by steve_weegie » Fri Apr 04, 2008 9:34 am
2F45T4U wrote:you will get a 2nd hand head from persley for about £25 (probably cheaper than arsing about with helicoils) , get a gasket set and you would be as well doing the job right if your thinking the head has to come off anyway.
If anyone sees a 2nd hand VVC head for £25, please oh please let me know..... ;)
Post by Rich H » Fri Apr 04, 2008 10:19 am
I think he may have missed a Zero off... :shock:
2F45T4U
Post by 2F45T4U » Fri Apr 04, 2008 11:04 am
oh ye. didnt realise it was a VVC. head off and helicoil it is then
caleebra
Post by caleebra » Mon Apr 07, 2008 10:53 am
Dropped it off at Falconers last night after a renewed plea on Saturday! Disconnected the injector and drove it out to Blackburn on 3 cylinders, very embarassing. So they're gonna do it in-situ, just keeping fingers crossed they dont phone up and say "Poke this they're too far down in there, come take it back!" Not because I really will hve to take the head off, but because I'll have to drive the fecker again.
Lee
steve_weegie
Post by steve_weegie » Mon Apr 07, 2008 11:23 am
Fingers crossed Lee! :thumbsup
caleebra
Post by caleebra » Tue Apr 08, 2008 12:08 am
Fixed :thumbsup only wanted £20 but I gave him £30 as he had a bit of a wreslte with the roof earlier in the day!
Replaced the rest of the plugs tonight and put it back together, seems to be running fine. Still got a MIL but will hook up the laptop to try and clear any DTCs in t'mornin.
Lee
caleebra
Post by caleebra » Tue Apr 08, 2008 12:12 am
PS he did not have a lot of good things to say about K-series :o despite the fact they must've given him lots of business over the years!! Had a VVC top end on the bench in bits with a cracked "half cam" - £££££! My GF was a bit gutted haha.
Lee
Post by Rich H » Tue Apr 08, 2008 8:26 am
£30 is a bargin, nice one! :D
steve_weegie
Post by steve_weegie » Tue Apr 08, 2008 2:04 pm
Top result! :D
