Sick Engine -was wet - Now fixed - what is the best fix ?
Re: Sick Engine -was wet - Now fixed - what is the best fix ?
Post by mac » Thu Aug 21, 2008 4:43 pm
I'm sure I could make a foam mould the next time I'm pouring a new seat - then all you need to do is get creative with the ole glass fibre :thumbsup
thinfourth
Post by thinfourth » Fri Aug 22, 2008 7:34 am
The 7 is even worse for this. my solution is a strip of duct tape down either side of the plug cover and never had a problem again
Post by robin » Fri Aug 22, 2008 7:52 am
You cannot fit the EU3 rain cover to EU2 engines because the EU3 uses a plug top coil system and so has no port for running the EU2 plug leads through.
You could modify the cover so that it would work, you would want to blank off the EU3 cam position sensor at the same time.
I think Thinfourth's approach is a reasonable one, except that the tape will probably peel off from time to time.
Silicone sealant is probably best.
skellyjohn
Post by skellyjohn » Fri Aug 22, 2008 8:27 am
Silly question, but where excatly does the silicone go?
s1 111s (kind of)
Post by campbell » Fri Aug 22, 2008 9:29 pm
robin wrote:You cannot fit the EU3 rain cover to EU2 engines because the EU3 uses a plug top coil system and so has no port for running the EU2 plug leads through.
Think I'd like to take a look at one of these then, even I can drill holes in plastic ;-)
Post by robin » Fri Aug 22, 2008 11:34 pm
skellyjohn wrote:Silly question, but where excatly does the silicone go?
Remove the spark plug cover; run a bead down the two long sides of the cam cover, and perhaps down the short edge where the cam cover meets the rear timing belt cover.
Also, remove the rubber bung that the spark plug leads clip into and put silicone underneath and up the two short sides, then stick it back in - this will stop water running up that way - don't seal the top of the bung, though as you want somewhere for some air flow.
Refit the spark plug cover while the silicone is still not set; it will squidge out the gaps - you can wipe clean any excess on the outside before it sets.
Leave the end that the spark plug leads run through open for ventilation purposes!
Now of course when you next remove the spark plug cover it's going to undo all your hard work - but if you do a good job you may find you've created a rubbery gasket that will work - if not, a quick run over with the stanley blade and reseal it.
Another option would be to use some old bicycle inner tube to create some edging strips that you can silicone in to the channel in the cam cover and that the spark plug cover will then clamp down onto, IYSWIM.
Post by robin » Fri Aug 22, 2008 11:36 pm
You're welcome to take a look at the one on my engine - Andy may also have one spare as we took one off the EU3 engine that went into the RLC.
Post by Rich H » Fri Aug 22, 2008 11:42 pm
Why not use soemthing like RTV and lightly oil the engine top before assembly, that way the RTV doesn't stick to the enigne and you get a gasket bonded to the cover... :wink:
Post by robin » Sat Aug 23, 2008 8:09 am
Good idea.
Post by campbell » Sat Aug 23, 2008 9:26 am
Ta. Access to an un-needed spare would be great. I'll nudge Andy when he has recovered from FF then ;-)
Er, shouldn't you be on the road btw?! What way you going?
