Expert advice .Chassis damage?
p4ilip
Re: Expert advice .Chassis damage?
Post by p4ilip » Wed Sep 16, 2009 1:00 am
Just a quick question, the cooling pipe looks a bit squashed. It looks like i could cut the squashed section out and replace it with a rubber hose if i had to. Is it possible to buy this pipe?
Post by Mikie711 » Wed Sep 16, 2009 6:13 am
Right hand and left are the same, part number is A111K0041F but there is an option part which is A111K0005 R/B. Have your chassis number handy when you order as that will tell them which one to get.
Mike
Jacobite
Post by Jacobite » Sun Sep 20, 2009 11:27 pm
The coolant pipe is clipped in place with zip ties in a couple of place on its length but the sills have 2 plastic formers at 90 degrees bonded to the sill and with a cut out around the pipe ~not a problem if your replacing the sill anyway but may cause a bit of bother if your not ~at least the rear end of the sill has some access with the rear clam off so cutting the pipe may be the answer
