No idea, when I called Lotus originally I didn't even check because they were stockout, I remembered the last time I bought from EP they seemed decent value, but they were also stockout this time, so I have since gone to EliseShop and they took my order happily then advised they had only 1 (I need 2) but would I like part-shipment. However they get from Xparts, and the hub looks cosmetically different to the EP one, so as things play out I'm going to end up with 2 ES ones on the back and 2 EP ones at the front. Mongrel or whatFerg wrote:Whats the price difference between Lotus and the uprated EP one?campbell wrote: Sadly we couldn't get fresh hub flanges at the time, backorder
Pre Spa spannering "UJI" by the dynamic duo
Re: Pre Spa spannering "UJI" by the dynamic duo
Well we finally finished off UJI yesterdya. A few minor things left on the to do list. Thought I would post some pics taken when breathers were needed from rounded hex bolts.
Brilliant, Sanjoy...some of those are priceless for caption comps I think!
A couple even infer that I know what I am doing
Really appreciate the pictorial record, actually.
Lisa took the Elise to work today for a further shakedown. Well, she made it there. In 3 hrs we'll see if she makes it back. The interesting thing is she told me "I LOVE that wee car, it is running great, you surely must keep it after all the work you've done!". Well well.
Campbell:"Hey, Sanjoy! I've found your lightsaber..."
Priceless, Ferg, nice one
Halloween in the Garage - the headless mechanic puts the finishing touches to the cooling system as the ghostly apparition that once was Sanjoy looks on......
- BiggestNizzy
I thought compo from last of the summer wine was dead.
ah but he had a green hat
with holes in it
with holes in it
T-minus 3 days and 2 hours and counting...
Today I mostly mopped up the remaining jobs...
- drilled off a lower damper mount bolt which I managed to strip during installation a couple of weeks ago
This was a new experience for me, but I did rather well I think and didn't even hit myself in the eye with flying metal debris
- changed another set of damper mount bolts, at the rear...one more pair to go but one bolt short due to above foulup so that's for Monday night I think
- replaced the airbox hose, which had split around the time of my service in the summer...RDH Rob kindly sent me his pre-owned one, and it fits nicely...better made than mine (S2 plays S1, stands to reason
- re-checked the coolant level after all the radiator shenanigans, everything crossed however looks ok still...funny feeling it's the heater matrix giving off a whiff of coolant from time time, oh joy. Anyway that's for another day. Non-trackday critical (apparently we will just replumb our way past the matrix if it lets go properly, according to Race Engineer Fat Bob Fisics)
- removed the front bonnet, then drilled out the one remaining rivet holding the hinge to the front clam
If only this had shown up while the car was marooned at Sanjoy's...typically it started to fail once the clam was all back on and I was ready to drive away. Anyway, got the "hinge" out...another "let's use a bolt as a pivot" special from Lotus, come on guys. Lubed it up as best I could, then re-installed using bolts this time (even though I am now King Riveter after the radiator fan fitting kit stuff we did...!) Refitting and re-adjusting the bonnet to the hinge is hilarious for one person, mind you. Get an assistant if you ever have to do this. Same goes for adjusting the stiker pin for the bonnet latch.
General shakedown drive reveals all the same clonks and bangs as normal, but the new hub and bearing at the rear have cleared up the rear-wheel steer feature (!), and even on damp ground the car is feeling pretty planted. Nice. Reminds me why I've kept it, and why I've spent so many hours scrambling about it in weird positions, getting backache etc etc. She is back in her own garage for the first time in about 6 weeks I think. Have to remind Lisa it's no longer a dumping ground for general tatt
My travel toolkit & spares kit are broadly complete, just a few details to sort tomorrow, and all she needs now is a wash, a top up with fuel and the tyre pressures checked, and that's it...too late to tinker with anything else.
Yours tired yet with a decent sense of achievement,
Spanners Fordy.
Spanners Fordy.
Well done! Once you have an arsenal of tools and the realization that most things are possible with some effort then there will be no stopping you. However, eventually you reach the point where the time available to do the job is the limiting factor
See you soon!
See you soon!
Touche. Am pretty much on the fulcrum of that scenario, actually
Anyway, let's see how the old crate is after Spa first...
Tis a wonder that they are not running a book on us Campbell, if so I hope there are no winners. As ever my main worry is CV joints, and Robin found some play in the new one that was fitted recently.
- Fluoxetine
Excellent work, Campbell - I now know who to look to, for technical support with regard to my winter supercharging project!
It's great to see UJI receiving some TLC...You must be one of the very very few SE'er's, who've owned their S1 from new. It really is like part of the SE family, with several Stelvio's / N'ring trip / numerous road runs under its belt over the past 11 years or so.
Personally, I was very impressed when I had the chance to drive it at Donnie last year - It's a sweet handling little car, with a nice spread of torque (I do appreciate it's on S2 Billys / has a Sabre head!
You'll have a great time at Spa - wet or dry. It's a fantastic track, and absolutely amazing to drive around. (You'll have new-found respect for the F1 pilots, espec. in the wet!
Have a blast, and will look forward to the trip report / pics!
Thanks Ross, and Robin, for appreciative remarks. I think I have somewhat surprised myself...although some may say many of the tasks I've taken on are by no means that difficult in the grand scheme of things. All relative though.
Ross, the tool "arsenal" is by no means complete but it is getting pretty respectable, at least by Elise standards, so I'd be more than happy to help with your winter project! In between doing my own, of course, which may well involve taking both clams off UJI and stripping and replacing wishbone bushes amongst other things
I am very much looking forward to Spa, and indeed the entire "SE On Tour" experience which has been long absent for me since the wee ones were born
I have no expectations other than to have fun, and bring the car home in one piece.
