Door freezing (Audi TT)
philthy
Re: Door freezing (Audi TT)
Post by philthy » Fri Dec 10, 2010 2:36 pm
can of spray grease sorts this out, I had to do it on the drivers door too.
S1 Elige Audi 1.8T
S1 Elise Honda K20
VW T6.1 family bus
Post by Shug » Fri Dec 10, 2010 2:41 pm
philthy wrote:can of spray grease sorts this out, I had to do it on the drivers door too.
Didn't read Fd's post then... Just storing up problems for the future.
philthy
Post by philthy » Fri Dec 10, 2010 2:45 pm
nope :lol: just saw pretty pictures
to be fair I have done this on a few cars now without problems, maybe I am not keeping them long enough
S1 Elige Audi 1.8T
S1 Elise Honda K20
VW T6.1 family bus
craig1983
Post by craig1983 » Sun Dec 12, 2010 5:38 pm
Well....after my door finally gave up closing altogether, I had to drive home from the supermarket with the door tied to my leg to keep it closed over.....so I took it to audi.
Apparently its a known manufacturers fault with the door cabling, so both doors were fixed under warranty. I think the freezing temperatures just made the problem worse....
'06 111R Elise SOLD!
Mazda MX6, 2.5L V6 SOLD!
Seat Ibiza 1.9TDI....SOLD!
Audi TT 2.0L TDI......
Post by Dominic » Mon Dec 20, 2010 2:32 pm
craig1983 wrote: fault with the door cabling, .
I guess similar to stuck hand brakes - it's moisture frozen in the cable then.
When I had my Elise, it would regularly be frozen of a winter's morning; I would use an extension cable and my wife's hair dryer to warm the lock. Putting hot water in only adds more moisture to a problem already caused by moisture where it should not be!
GT85 FTW. The AA also advise to grease the rubber door seals - something I have never done, and probably would not bother with.
I was using a freelander a few weeks ago, the rear door has a frame-less window, which means when you open it, the window drops a wee bit; fine until it froze, and then I nearly pulled the glass out the door when opening it. I guess the TT has a similar arrangement with it's doors with the frame-less windows? If the window does not drop, is there a safety mechanism to prevent you opening the door?? :?
