Nitron and adjusting.
Re: Nitron and adjusting.
Post by robin » Thu Apr 28, 2011 1:16 pm
The difference between bumps and tramlining is that the car will travel over a bump on a more or less straight trajectory if you let go of the steering wheel (or at least allow the steering wheel to turn to whatever angle it wants to) whereas the car will follow the "tramline" unless you counter with some steering.
It's no problem to come out and pop on the road tyre'd rims if you want to do it, and in fact you could also drive my car back-to-back with yours as they are very similar apart from the camber.
Post by mckeann » Thu Apr 28, 2011 4:42 pm
they tyre pressures are a very easy fix, you can always change them back. I used to run them on the low side, so would help alot to increase them.
pete
Vexatious Litigant
Post by pete » Thu Apr 28, 2011 10:28 pm
Fixing the tyre pressures changed things a bit (did that soon after I got it). Not so much that they were all low as some of them were very low, whilst others were fine.
\i think i am just fiddling for fiddling's sake, which I was going to apologise for then realised that I'm hardly alone there :D :D
Thanks Robin, may well take you up on that, need to get some free time first but it would be interesting just for reference.
Pete
(Neil did you ever fit uprated toe links? Can you tell I just want to buy stuff - it is working at the moment and I've gone right off the idea of a respray so I'm looking for other things to do.)
'99 - '03 Titanium S1 111S.
'11 - '17 S2 135R
'17 - '19 S2 Exige S+
'23 - ?? Evora
Post by robin » Thu Apr 28, 2011 10:37 pm
Oh fcuk. Prepare for ape-spleen-vent. :-)
Post by mckeann » Thu Apr 28, 2011 11:52 pm
haha. dont make me tell my toe link stories.
Post by campbell » Fri Apr 29, 2011 3:16 pm
From my hazy memory, he fitted some fresh ones just slightly later than he ideally would have wanted to...ie, shortly after some "fun" on Mont Ventoux. Am I right Neil?!?!
Post by mckeann » Fri Apr 29, 2011 3:45 pm
see my post above :lol:
