How long before an Elise battery goes flat?
- alicrozier
Re: How long before an Elise battery goes flat?
I think you'd be easier taking the battery out of the car, it's really only a 2 min job.
Keep it nice and cosy in the house and charge if needed...
- GraemeLotus
Bear in mind that the central locking and manual locks on post -04 Elises are completely unconnected; if the door is locked with the central locking and the battery goes flat, you'll need to open the boot, jump the battery (the alarm will sound), then unlock the door with the plip....Tommy Twist wrote:Should the battery go dead, I take it I can still operate the door locks manually?
E92 325 C SE - Deutsch Verkehrsmitteln
I don't hold much hope for my VX battery. It will have been sat for 3 months in a mates garage by the time I get home. Bugger......
Some videos here http://www.youtube.com/user/lou924/vide ... &flow=grid
Hahahahaha.alicrozier wrote:I think you'd be easier taking the battery out of the car, it's really only a 2 min job.
Took me and my partner 25 minutes to change the one in my S1, and even then we ended up dropping a spanner to permanently live underneath the battery.
I can't see it doable in 2 minutes unless you a) really don't want any skin on your knuckles and b) don't care about breaking the radiator trim.
Bad girls don't drive Micras
In an S2 the battery lives in the boot so it is a very easy to remove, just remember to connect it up correctly when you replace it.
Alan
S2 111S
S2 111S
- Tommy Twist
Funnily enough, that's what I'd intended to do, until I read some posts about the battery being tricky to remove! However, in hindsight they might have been referring to an S1 battery. Thanks for posting and putting me right.alicrozier wrote:I think you'd be easier taking the battery out of the car, it's really only a 2 min job.
OK, thanks for posting – certainly useful to know!GraemeLotus wrote:Bear in mind that the central locking and manual locks on post -04 Elises are completely unconnected; if the door is locked with the central locking and the battery goes flat, you'll need to open the boot, jump the battery (the alarm will sound), then unlock the door with the plip....Tommy Twist wrote:Should the battery go dead, I take it I can still operate the door locks manually?
Cool, thanks for the info.AJT wrote:In an S2 the battery lives in the boot so it is a very easy to remove, just remember to connect it up correctly when you replace it.
I take it the alarm can be disabled prior to battery removal, to prevent it sounding when the battery is removed and refitted? (I'd consult the manual, but it's in the boot and the car cover is a bugger to remove and refit).
Thanks again!
S1 battery was an absolute nightmare
Motorsport K20 Elise
pah.... you wanna try a 340 mate, whole body has to come off!foz01 wrote:S1 battery was an absolute nightmare
Hairdresser at heart.
My bonnet won't open either
I am going to fit aerocaatches front and rear anyway I reckon..
quick Q : can i use a 1.25 amp charger for my car battery? or is this just not going to work....
- Tommy Twist
Wee update...
Car hasn't moved since this thread was started, but I disconnected the battery last week, in order to stop the alarm from intermittently sounding:
http://www.scottishelises.com/phpbb/vie ... =5&t=32411
Then today, as the weather forecast is milder and I hope to take the car out for a drive soon, I decided to remove the cover and reconnect the battery. Car started perfectly, didn't even labour turning over
So the empirical answer to the question seems to be:
- For at least two weeks, the battery will hold a charge strong enough to start the engine (bearing in mind that it was disconnected for around 60% of that period).
- The alarm might start complaining much sooner! (have to assume that the cold spell didn't help and caused a bit of a voltage drop).
Have done my S1 and Erica's VX a couple of times now, the trick is to use a belt (or buy a battery with a handle!)puffin wrote:Hahahahaha.alicrozier wrote:I think you'd be easier taking the battery out of the car, it's really only a 2 min job.
Battery with handle is a couple of minute job. Use the washer bottle to hold the bonnet open, disconnect / remove holding bracket and lift out (with 2nd person helping to move the loom).
The Vx battery doesn't actualy fit out (or the loom doesn't move enough) so the handle is pretty useless as you need to rotate the battery in!
I use the belt from my jeans, buckle it and use it as a long handle to lift out / lower in the battry
all that said, last week, I just hooked up a charger with the battery in position. Much easier!
Chris
a bit off this subject battery...but i though might be an interesting bit of info that i discovered with my Odyssey PC680 battery.
i was washing the car the other day and had the radio on with the sounds turned up nice and high to be able to hear outside, for an hour or so+ think i also had the ignition turned on....big mistake as i went to start ...no go!!
.....managed to leave the car for a while and tried again and luckily there was enough to get her started
I wont be doing that again!
1998 Audi Elige s1-1.8t 20v
- Lazydonkey
Just to update this thread, the VX turned a wheel for the first time in 2.5 weeks this morning.
Alarm was off and a £20 solar trickle charger from Maplin was connected.
Fair lept in to life
r10crw wrote:pah.... you wanna try a 340 mate, whole body has to come off!foz01 wrote:S1 battery was an absolute nightmare
Did it have a handle?
Had the battery in and out of mine countless times, never had any hassle.
