Evora Reverse Camera FAILURE
Re: Evora Reverse Camera FAILURE
well i went to take the car out the garage today and when going into reverse....guess what, the camera worked clear as day, I'm guessing it was maybe a bit of water in it which has dried out
Lotus Evora , previous car history Elise S2 , Mini Cooper S
Sounds like you need get the silicone in about it before it rains again!
Stewart
Stewart what part of the evora is it where you think the waters running into which may have caused this ? will it be the front grills on the bonnet
Surely it will be at the camera itself, water running from the boot channel? Unless you manage to seal it it will almost certainly give out eventually so your e-bay purchase won't be wasted, just not needed straight away.
The Evora may have some entertaining water ingress routes. Particularly at the rear. Mine has been in at Murray for some pretty detailed diagnosis. Rained hard this weekend so will be able to check results in the morning
one thing I've noticed about my camera and when wtxhing other review videos of the Evora, when you touch visual and then camera whilst driving the camera shows up however on mines it doesn't it just goes blank, how do i have this changed so i can check behind me whilst driving
and yea, j2 lot i will just keep the camera for a rainy day no pun intended
Jordan wrote: when you touch visual and then camera whilst driving the camera shows up however on mines it doesn't it just goes blank,
ooohh didnt know you could do that - I really havent worked out how the Alpine unit works yet- I ve (just) got enough understanding to do what I need it to but not invested any time in seeing what else it can do
Any pointers for areas to check on the Evora for water ingress? The other week the car had light condensation inside which was slow to clear and appeared again when the air con was off (10 degrees C and no rain). Carpets feel dry. When you put the door windows down and up they are wet even when the car is dry which is a bit strange.campbell wrote:The Evora may have some entertaining water ingress routes. Particularly at the rear. Mine has been in at Murray for some pretty detailed diagnosis. Rained hard this weekend so will be able to check results in the morning
No lotus
Exige Sport 350 (Sold)
Evora S (sold)
Evora S (sold)
There's a harness runs down the front driver side of the engine bay. If rain leaks in it can run down then "wick" its way into rear seat cushion.
I also wonder if mine has some ingress under windscreen or front svc compartment, to driver side mat. But not conclusive.
Ta, will have a Check.campbell wrote:There's a harness runs down the front driver side of the engine bay. If rain leaks in it can run down then "wick" its way into rear seat cushion.
No lotus
Evora S (sold)
Evora S (sold)
