Foam inside coolant
pshanks76
Re: Foam inside coolant
Post by pshanks76 » Sat Apr 23, 2016 12:42 pm
My header tank looked similar and I ended up having an oil to coolant leak as Robin described. The gunk in the header tank was the only sign, no overheating, no gunk under the oil filler cap. Before getting my HG replaced I did remove the tank (drained it with a syringe) then washed out with hot water and Fairy and replaced and topped back up. I did then find the residue slowly returning and there was a slight oily smell after it had been run so did a home gas test and confirmed. Fingers crossed it's not a HGF but if it is and this is the only sign, at least it's likely you caught it before it did any further damage.
Elise S2 135r no more... Crossed to the dark side with a Boxster 981s
BMW 330D x-drive m-sport touring
Autosleeper Duetto camper
StiflerMR2
Post by StiflerMR2 » Sat Apr 23, 2016 1:02 pm
Thanks for the info, been on the phone to Craig and Calum so will be dropping it off with them post SIDC next month for some diagnosis.
Removed the scum this morning so will take it for a run tomorrow and see if it comes back, but tbh, it was more sludge than foam..... not looking good.
If it is the worst case scenario it may be a chance to release a few more ponies, if I was looking for a silver lining.
StiflerMR2
Post by StiflerMR2 » Sun May 22, 2016 7:02 am
Just to update, looks like it was indeed signs of early HGF :(
Craig is currently working his magic on it and looks to have been caught early enough to not be too serious.
Post by Stephen » Sun May 22, 2016 7:12 am
Glad to hear that you caught it in time.
Post by j2 lot » Sun May 22, 2016 7:10 pm
:thumbsup good that you caught it in time
Post by robin » Sun May 22, 2016 7:33 pm
The root cause of the elastomer failure might be hard to identify; first time around if there is nothing obvious I would just replace and move on. You should measure the liner heights, simply because you are there, but probably do nothing about them unless very bad. But if it fails again ... well, there are as many theories as there are web sites dedicated to the K-series engine on how you should/could fix it ...
Post by campbell » Sun May 22, 2016 11:58 pm
HOOOONNNNNNDDDDAAAAAA!
Just kidding. I think.
StiflerMR2
Post by StiflerMR2 » Mon May 23, 2016 7:11 am
Unless an installation is coming in around 3k these days then no ;)
I actually like the k, it has a bit of character. Just a shame it's character is jekyll and Hyde ;)
Post by Dominic » Mon May 23, 2016 9:27 am
Glad I am not alone. :blackeye :oops:
Post by Stephen » Mon May 23, 2016 1:14 pm
With mine being a 160. I'm kind of stuck with the k unless I want to change the nature of the car completely, if you know what I mean. Dom is some the same with a 135.
StiflerMR2
Post by StiflerMR2 » Mon May 23, 2016 2:32 pm
I do, I wouldn't want to change either of those!
With mine being a run of the mill 118bhp there is nothing sacred about it. It's more I like the K's nature and the lack of funds to drop a honda in :D
